Hi @tedwu1,
Just to confirm, what are the modifications that you are doing? are you changing the adv data? what is the low power mode that you are working on?
However, could you please work with the Bluetooth LE version 4.2? qn9020b4_lib_peripheral_v42.a
Also depending on the MCU version that you have.
Did you look at the next AN?
https://www.nxp.com/docs/en/application-note/AN11814.pdf
Mario
