The best way to build a PCB first time right with KW45 (Automotive) or K32W1/MCXW71 (IoT/Industrial)
26,007件の閲覧回数
christophe_menard
Please, find the important link to build a PCB using a KW45 or K32W1 & MCX W71 and all concerning the radio performances, low power and radio certification (CE/FCC/IC).
KW45 product NXP web page:
https://www.nxp.com/products/wireless/bluetooth-low-energy/32-bit-bluetooth-5-3-long-range-mcus-with...
K32W1 product NXP web page:
https://www.nxp.com/products/wireless/multiprotocol-mcus/tri-core-secure-and-ultra-low-power-mcu-for...
MCX W71 product NXP web page:
https://www.nxp.com/products/processors-and-microcontrollers/arm-microcontrollers/general-purpose-mc...
KW45-EVK getting started NXP web page:
https://www.nxp.com/products/processors-and-microcontrollers/kw45b41z-evaluation-kit-with-bluetooth-...
https://www.nxp.com/document/guide/getting-started-with-the-kw45b41z-evaluation-kit:GS-KW45B41ZEVK
K32W1-EVK getting started NXP web page:
https://www.nxp.com/products/processors-and-microcontrollers/k32w148-evaluation-kit-with-multiprotoc...
https://www.nxp.com/document/guide/getting-started-with-the-k32w148-development-platform:GS-K32W148E...
FRDM-MCXW71 / MCXW71-EVK getting started NXP web page:
https://www.nxp.com/document/guide/getting-started-with-frdm-mcxw71:GS-FRDM-MCXW71
HARDWARE
    KW45-EVK HW guideline: Hardware Design Considerations for KW45B41Z and K32W148 Bluetooth LE Devices (nxp.com)
    MCXW W71 HW guideline: MCXW71 Hardware Design Guide
    KW45B41Z-EVK User Manual https://www.nxp.com/docs/en/user-manual/KW45B41Z-EVKUM.pdf
    K32W1-EVK User Manual: K32W148-EVK Board User Manual (nxp.com)
    FRDM-MCXW71 USer Manual: FRDM-MCXW71 Board User Manual
     Minimum BoM (attached file)
    DCDC management guide (AN13831): 'NXP account required to access this content KW45/K32W148 - Power Management Hardware[AN13831]' from https://www.nxp.com/products/KW45
    Migration guide: KW38 to KW45: Available on demand
    Design-In check list: excel file attached
    RF matching: S parameters (attached file)
    ESD: Please note as raised in the KW45 datasheet, the ElectroStatic Discharge of the RF antenna pin is +/-250V (change-device model). In case the targeted system need to pass larger ESD target then an external ESD diode is recommended. The following reference are foressen as acceptable : Nexperia PESD5V0C1BLS-Q, littlefuse SP3522-01ETG, SPSEMI AUSD05CBL.
IMPORTANT Information; launch prototype before production platform to fine tune RF path:
“As RF behavior are dependent of PCB layout & manufacturing; PCB prototypes (based on NXP recommendations) will have to be fine-tuned to insure the expected qualified in RF is reached on the final productized platform.”
RADIO
    RF report: KW45 and K32W148 RF System Evaluation Report for Bluetooth LE and K32W148 for 802.15.4 Applications ...
FRDM-MCXW71 RF System Evaluation Report for Bluetooth LE and IEEE 802.15.4 Applications
    Radio co-existence: Kinetis Wireless Family Products Bluetooth Low Energy Coexistence with Wi-Fi Application (nxp.com)
    Distance performances: refer to attached file
    Antenna:
Compact Planar Antennas for 2.4 GHz Communication Designs and Applications within NXP EVK Boards
Antennas for Channel Sounding Applications
    Generic FSK Link Layer Quick Start (attached file)
    BLE connectivity test binary file:  SDK_x_xx_x_KW45B41Z-EVK\boards\kw45b41zevk\wireless_examples\genfsk\connectivity_test\bm\iar\
    K32W148 Connectivity Test for 802.15.4 Application (nxp.com)
    Return loss (S11) measurement: How to measure the return loss of your RF matching (S11)
                   part of the RF report (AN13728)
    Loadpull: Kinetis KW45 and K32W148 Loadpull Report (nxp.com)  ; MCX W71 Loadpull Report
SW tools:
    IoT Tool box (mobile application)
    Connectivity test tool for connectivity products (part of the IoT toolbox)
    DTM: How to use the HCI_bb on Kinetis family products a... - NXP Community
https://community.nxp.com/t5/Wireless-Connectivity-Knowledge/BLE-HCI-Application-to-set-transmitter-...
CRYSTAL
Article 1 : KW45/K32W1 32MHz & 32kHz Oscilllation margins - NXP Community
Article 2 : KW45/K32W1 32MHz & 32kHz Oscilllation margins
32kHz crystal-less application note
KW36 - Trimming adjust of 32MHz XTAL external osci... - NXP Community
KW45 / MCX W71 - Trimming adjust of 32MHz & 32kHz external crystals - NXP Community
LOW POWER
  Estimator Tool
https://community.nxp.com/t5/Wireless-Connectivity/Kinetis-KW35-38-KW45-amp-K32W1-MCXW71-Power-Profi...
KW45_WK47_MCXW71_MCXW72_BLE_power_profile_calculator_v1.34.xlsx
MCX W7x 802.15.4 Matter ICD SIT LIT & ZED Power profile v0.6.xlsx
    Low Power Consumption: https://www.nxp.com/docs/en/application-note/AN13230.pdf
    MCX W71 Bluetooth LE Power Consumption Analysis
AN MCX W72 802.15.4 Matter and Zigbee Power profile analysis.pdf
CERTIFICATION
KW45
European Union Declaration of Conformity for KW45B41Z-EVK Evaluation Kit
European Union Declaration of Conformity for KW45B41Z-LOC
K32W148
European Union Declaration of Conformity for K32W148-EVK Evaluation Kit
7 返答(返信)
22,734件の閲覧回数
xing_chang
Hi @christophe_menard ,
In the checklist, we should add a check on the external watchdog, note that if the customer uses the OTA function, when upgrading the firmware, the time required after reset may reach a few seconds, which requires special attention from the external watchdog.
23,284件の閲覧回数
suleymansekerci
Does anyone help me to about the value of power consumption for KW54 in three modes( PMIC, DCDC, Bypass) ?
23,250件の閲覧回数
christophe_menard
Hi Suleymansekerci,
Could you precise your request about the three modes( PMIC, DCDC, Bypass), please?
For your help, you could refer to the AN13230 Kinetis KW45 & K32W1 Bluetooth LE Power Consumption Analysis available in NXP site and playing with the KW45_BLE_power_profile_calculator_v1.5.xlsx file.
For your guidance, the most safe power is the buck mode (DCDC inside the Kinetis product)  for sure without any extra BoM cost.
23,232件の閲覧回数
suleymansekerci
Dear Menard,
Thanks  for your reply.
25,517件の閲覧回数
christophe_menard
Hi Marko,
The added components are not the same on the 3 use cases.
25,520件の閲覧回数
christophe_menard
Hi Marko,
The valus are correct. The added components are not the same on the 3 use cases.
25,528件の閲覧回数
marko_pavlin
Hi, I am looking the "minimum BOM" document. At the end, there is a table with con-cell operation recommendation:
Is this OK? 10dBm <1mA, ... 0dBm : 4,5mA ?
%3CLINGO-SUB%20id%3D%22lingo-sub-1592481%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EKW45%EF%BC%88%E3%82%AA%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%96%EF%BC%89%E3%81%BE%E3%81%9F%E3%81%AFK32W1%2FMCXW71%EF%BC%88IoT%2F%E3%82%A4%E3%83%B3%E3%83%80%E3%82%B9%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%EF%BC%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%88%9D%E3%82%81%E3%81%A6PCB%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E6%9C%80%E8%89%AF%E3%81%AE%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1592481%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EKW45%20%E3%81%BE%E3%81%9F%E3%81%AF%20K32W1%20%E3%81%A8%20MCX%20W71%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20PCB%20%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E9%87%8D%E8%A6%81%E3%81%AA%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%A8%E3%80%81%E7%84%A1%E7%B7%9A%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%80%81%E4%BD%8E%E9%9B%BB%E5%8A%9B%E3%80%81%E7%84%A1%E7%B7%9A%E8%AA%8D%E8%A8%BC%20(CE%2FFCC%2FIC)%20%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E6%83%85%E5%A0%B1%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22christophe_menard_0-1712329547355.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22christophe_menard_0-1712329547355.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F272220i0E47A6371A6C64EA%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22christophe_menard_0-1712329547355.png%22%20alt%3D%22christophe_menard_0-1712329547355.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EKW45%E8%A3%BD%E5%93%81NXP%E3%82%A6%E3%82%A7%E3%83%96%E3%83%9A%E3%83%BC%E3%82%B8%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fwireless%2Fbluetooth-low-energy%2F32-bit-bluetooth-5-3-long-range-mcus-with-can-fd-and-lin-bus-options-arm-cortex-m33-core%3AKW45%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fproducts%2Fwireless%2Fbluetooth-low-energy%2F32-bit-bluetooth-5-3-long-range-mcus-with...%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EK32W1%20%E8%A3%BD%E5%93%81%20NXP%20%E3%82%A6%E3%82%A7%E3%83%96%E3%83%9A%E3%83%BC%E3%82%B8%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fwireless%2Fmultiprotocol-mcus%2Ftri-core-secure-and-ultra-low-power-mcu-for-matter-over-thread-and-bluetooth-le-5-3%3AK32W148%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fproducts%2Fwireless%2Fmultiprotocol-mcus%2Ftri-core-secure-and-ultra-low-power-mcu-for...%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EMCX%20W71%20%E8%A3%BD%E5%93%81%20NXP%20%E3%82%A6%E3%82%A7%E3%83%96%E3%83%9A%E3%83%BC%E3%82%B8%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-microcontrollers%2Fgeneral-purpose-mcus%2Fmcx-arm-cortex-m%2Fmcx-w-series-microcontrollers%2Fmcx-w71x-secure-and-ultra-low-power-mcus-for-matter-thread-zigbee-and-bluetooth-le%3AMCX-W71X%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-microcontrollers%2Fgeneral-purpose-mcus%2Fmcx-arm-cortex-m%2Fmcx-w-series-microcontrollers%2Fmcx-w71x-secure-and-ultra-low-power-mcus-for-matter-thread-zigbee-and-bluetooth-le%3AMCX-W71X%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EKW45-EVK%20%E5%85%A5%E9%96%80%20NXP%20Web%20%E3%83%9A%E3%83%BC%E3%82%B8%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Fkw45b41z-evaluation-kit-with-bluetooth-low-energy%3AKW45B41Z-EVK%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Fkw45b41z-evaluation-kit-with-bluetooth-low-energy%3AKW45B41Z-EVK%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fgetting-started-with-the-kw45b41z-evaluation-kit%3AGS-KW45B41ZEVK%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fgetting-started-with-the-kw45b41z-evaluation-kit%3AGS-KW45B41ZEVK%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EK32W1-EVK%20%E5%85%A5%E9%96%80%20NXP%20Web%20%E3%83%9A%E3%83%BC%E3%82%B8%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Fk32w148-evaluation-kit-with-multiprotocol-radio%3AK32W148-EVK%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Fk32w148-evaluation-kit-with-multiprotocol-radio%3AK32W148-EVK%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fgetting-started-with-the-k32w148-development-platform%3AGS-K32W148EVK%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fgetting-started-with-the-k32w148-development-platform%3AGS-K32W148EVK%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EFRDM-MCXW71%20%2F%20MCXW71-EVK%20%E5%85%A5%E9%96%80%20NXP%20%E3%82%A6%E3%82%A7%E3%83%96%E3%83%9A%E3%83%BC%E3%82%B8%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fgetting-started-with-frdm-mcxw71%3AGS-FRDM-MCXW71%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fgetting-started-with-frdm-mcxw71%3AGS-FRDM-MCXW71%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EKW45-EVK%20HW%E3%82%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN13227.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EKW45B41Z%E3%81%8A%E3%82%88%E3%81%B3K32W148%20Bluetooth%20LE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E8%A8%AD%E8%A8%88%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%80%83%E6%85%AE%E4%BA%8B%E9%A0%85%EF%BC%88NXP.com%EF%BC%89%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EMCXW%20W71%20HW%E3%82%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%3A%20%3CA%20id%3D%22relatedDocsClickHTML_1%22%20class%3D%22dtmcustomrulelink%22%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FUG10146%2Fpage%2Ftopics%2Fintroduction.html%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%20data-dtmaction%3D%22Documentation%20Section%20-%20Results%20Link%20Click%22%20data-dtmsubaction%3D%22MCXW71%20Hardware%20Design%20Guide%20-%20NXP%20-%20User%20Guide%20-%20English%22%3E%3CSPAN%3EMCXW71%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%82%AC%E3%82%A4%E3%83%89%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EKW45B41Z-EVK%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-manual%2FKW45B41Z-EVKUM.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-manual%2FKW45B41Z-EVKUM.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EK32W1-EVK%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%3A%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2FpreDownload.jsp%3Frender%3Dtrue%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EK32W148-EVK%20%E3%83%9C%E3%83%BC%E3%83%89%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%20(nxp.com)%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EFRDM-MCXW71%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%3A%20%3CA%20id%3D%22relatedDocsClickHTML_1%22%20class%3D%22dtmcustomrulelink%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DUM12063%26amp%3BisHTMLorPDF%3DHTML%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%20data-dtmaction%3D%22Documentation%20Section%20-%20Results%20Link%20Click%22%20data-dtmsubaction%3D%22FRDM-MCXW71%20Board%20User%20Manual%20-%20NXP%20-%20User%20Manual%20-%20English%22%3E%3CSPAN%3EFRDM-MCXW71%20%E3%83%9C%E3%83%BC%E3%83%89%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%9C%80%E5%B0%8FBoM%EF%BC%88%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%EF%BC%89%3C%2FP%3E%0A%3CP%3EDCDC%20%E3%83%9E%E3%83%8D%E3%82%B8%E3%83%A1%E3%83%B3%E3%83%88%E3%82%AC%E3%82%A4%E3%83%89%20(AN13831)%3A%20%E3%80%8C%E3%81%93%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%86%E3%83%B3%E3%83%84%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%20NXP%20%E3%82%A2%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%3CA%20id%3D%22relatedDocsClickPDF_26%22%20class%3D%22dtmcustomrulelink%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DAN13831%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%20data-dtmaction%3D%22Documentation%20Section%20-%20Results%20Link%20Click%22%20data-dtmsubaction%3D%22KW45%2FK32W148%20-%20Power%20Management%20Hardware%20-%20NXP%20-%20Application%20Note%20-%20English%22%20data-cl-id%3D%223217761592%22%3E%3CSPAN%3EKW45%2FK32W148%20-%20%E3%83%91%E3%83%AF%E3%83%BC%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A1%E3%83%B3%E3%83%88%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20class%3D%22code-id%22%3E%5BAN13831%5D%E3%80%8D%3C%2FSPAN%3E%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2FKW45%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fproducts%2FKW45%3C%2FA%3E%E3%82%88%E3%82%8A%3C%2FP%3E%0A%3CP%3E%E7%A7%BB%E8%A1%8C%E3%82%AC%E3%82%A4%E3%83%89%3A%20KW38%20%E3%81%8B%E3%82%89%20KW45%3A%3CEM%3E%E3%82%AA%E3%83%B3%E3%83%87%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%82%A4%E3%83%B3%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%3A%20Excel%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%B7%BB%E4%BB%98%3C%2FP%3E%0A%3CP%3ERF%E3%83%9E%E3%83%83%E3%83%81%E3%83%B3%E3%82%B0%EF%BC%9A%20%3CEM%3ES%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%EF%BC%88%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%EF%BC%89%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3EESD%3A%20KW45%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81RF%20%E3%82%A2%E3%83%B3%E3%83%86%E3%83%8A%20%E3%83%94%E3%83%B3%E3%81%AE%E9%9D%99%E9%9B%BB%E6%94%BE%E9%9B%BB%E3%81%AF%20%2B%2F-250V%20(%E5%A4%89%E6%9B%B4%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%A2%E3%83%87%E3%83%AB)%20%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%AF%BE%E8%B1%A1%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%82%88%E3%82%8A%E5%A4%A7%E3%81%8D%E3%81%AA%20ESD%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%92%E9%80%9A%E9%81%8E%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8BCASE%E3%81%AF%E3%80%81%E5%A4%96%E9%83%A8%20ESD%20%E3%83%80%E3%82%A4%E3%82%AA%E3%83%BC%E3%83%89%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%8C%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AE%E5%8F%82%E7%85%A7%E3%81%8C%E8%A8%B1%E5%AE%B9%E5%8F%AF%E8%83%BD%E3%81%A8%E3%81%BF%E3%81%AA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3A%20Nexperia%20PESD5V0C1BLS-Q%E3%80%81littlefuse%20SP3522-01ETG%E3%80%81SPSEMI%20AUSD05CBL%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22matthieu_baudry_0-1737532608614.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22matthieu_baudry_0-1737532608614.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F320792i44F2BDE229467915%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22matthieu_baudry_0-1737532608614.png%22%20alt%3D%22matthieu_baudry_0-1737532608614.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%87%8D%E8%A6%81%E3%81%AA%E6%83%85%E5%A0%B1%3A%20RF%20%E3%83%91%E3%82%B9%E3%82%92%E5%BE%AE%E8%AA%BF%E6%95%B4%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E7%94%9F%E7%94%A3%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%AE%E5%89%8D%E3%81%AB%E3%83%97%E3%83%AD%E3%83%88%E3%82%BF%E3%82%A4%E3%83%97%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%80%8CRF%20%E3%81%AE%E5%8B%95%E4%BD%9C%E3%81%AF%20PCB%20%E3%81%AE%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%81%A8%E8%A3%BD%E9%80%A0%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E6%9C%80%E7%B5%82%E8%A3%BD%E5%93%81%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A7%E6%9C%9F%E5%BE%85%E3%81%95%E3%82%8C%E3%82%8B%20RF%20%E3%81%AE%E8%AA%8D%E5%AE%9A%E3%81%8C%E9%81%94%E6%88%90%E3%81%95%E3%82%8C%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81PCB%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%BF%E3%82%A4%E3%83%97%20(NXP%20%E3%81%AE%E6%8E%A8%E5%A5%A8%E4%BA%8B%E9%A0%85%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F)%20%E3%82%92%E5%BE%AE%E8%AA%BF%E6%95%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%80%8D%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E%E7%84%A1%E7%B7%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3ERF%E3%83%AC%E3%83%9D%E3%83%BC%E3%83%88%3A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN13728.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EBluetooth%20LE%20%E3%81%8A%E3%82%88%E3%81%B3%20802.15.4%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E5%90%91%E3%81%91%20KW45%20%E3%81%8A%E3%82%88%E3%81%B3%20K32W148%20RF%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E8%A9%95%E4%BE%A1%E3%83%AC%E3%83%9D%E3%83%BC%E3%83%88%20...%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CA%20id%3D%22relatedDocsClickHTML_1%22%20class%3D%22dtmcustomrulelink%22%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FAN14374%2Fpage%2Ftopics%2Fintroduction.html%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%20data-dtmaction%3D%22Documentation%20Section%20-%20Results%20Link%20Click%22%20data-dtmsubaction%3D%22FRDM-MCXW71%20RF%20System%20Evaluation%20Report%20for%20Bluetooth%20LE%20and%20IEEE%20802.15.4%20Applications%20-%20NXP%20-%20Application%20Note%20-%20English%22%3E%3CSPAN%3EFRDM-MCXW71%20Bluetooth%20LE%E3%81%8A%E3%82%88%E3%81%B3IEEE%20802.15.4%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E5%90%91%E3%81%91RF%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E8%A9%95%E4%BE%A1%E3%83%AC%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E7%84%A1%E7%B7%9A%E5%85%B1%E5%AD%98%3A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN13512.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EKinetis%20%E3%83%AF%E3%82%A4%E3%83%A4%E3%83%AC%E3%82%B9%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E8%A3%BD%E5%93%81%20Bluetooth%20Low%20Energy%20%E3%81%A8%20Wi-Fi%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A8%E3%81%AE%E5%85%B1%E5%AD%98%20(nxp.com)%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E9%81%A0%E9%9A%94%E5%85%AC%E6%BC%94%EF%BC%9A%3CSPAN%3E%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%8F%82%E7%85%A7%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%82%A2%E3%83%B3%E3%83%86%E3%83%8A%EF%BC%9A%20%3CA%20id%3D%22relatedDocsClickPDF_1%22%20class%3D%22dtmcustomrulelink%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DUG10107%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%20data-dtmaction%3D%22Documentation%20Section%20-%20Results%20Link%20Click%22%20data-dtmsubaction%3D%22Antennas%20for%20Channel%20Sounding%20Applications%20-%20NXP%20-%20User%20Guide%20-%20English%22%3E%3C%2FA%3E%3C%2FP%3E%0A%3CP%20class%3D%22lia-indent-padding-left-30px%22%20style%3D%22padding-left%20%3A%2030px%3B%22%20style%3D%22padding-left%20%3A%2030px%3B%22%3E%3CA%20id%3D%22relatedDocsClickPDF_13%22%20class%3D%22dtmcustomrulelink%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN2731.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%20data-dtmaction%3D%22Documentation%20Section%20-%20Results%20Link%20Click%22%20data-dtmsubaction%3D%22Compact%20Planar%20Antennas%20for%202.4%20GHz%20Communication%20Designs%20and%20Applications%20within%20NXP%20EVK%20Boards%20-%20NXP%20-%20Application%20Note%20-%20English%22%3E%3CSPAN%3ENXP%20EVK%E3%83%9C%E3%83%BC%E3%83%89%E5%86%852.4GHz%E9%80%9A%E4%BF%A1%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%2F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E7%94%A8%E5%B0%8F%E5%9E%8B%E5%B9%B3%E9%9D%A2%E3%82%A2%E3%83%B3%E3%83%86%E3%83%8A%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%0A%3CP%20class%3D%22lia-indent-padding-left-30px%22%20style%3D%22padding-left%20%3A%2030px%3B%22%20style%3D%22padding-left%20%3A%2030px%3B%22%3E%3CA%20id%3D%22relatedDocsClickPDF_1%22%20class%3D%22dtmcustomrulelink%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DUG10107%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%20data-dtmaction%3D%22Documentation%20Section%20-%20Results%20Link%20Click%22%20data-dtmsubaction%3D%22Antennas%20for%20Channel%20Sounding%20Applications%20-%20NXP%20-%20User%20Guide%20-%20English%22%3E%3CSPAN%3E%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%82%B5%E3%82%A6%E3%83%B3%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E7%94%A8%E3%82%A2%E3%83%B3%E3%83%86%E3%83%8A%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%B1%8E%E7%94%A8FSK%E3%83%AA%E3%83%B3%E3%82%AF%E5%B1%A4%E3%82%AF%E3%82%A4%E3%83%83%E3%82%AF%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%EF%BC%88%3CEM%3E%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%EF%BC%89%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3EBLE%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%E3%83%86%E3%82%B9%E3%83%88%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20SDK_x_xx_x_KW45B41Z-EVK%5Cboards%5Ckw45b41zevk%5Cwireless_examples%5Cgenfsk%5Cconnectivity_test%5Cbm%5Ciar%5C%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN13687.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EK32W148%20802.15.4%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%83%86%E3%82%B9%E3%83%88%20(nxp.com)%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%83%AA%E3%82%BF%E3%83%BC%E3%83%B3%E3%83%AD%E3%82%B9%EF%BC%88S11%EF%BC%89%E6%B8%AC%E5%AE%9A%EF%BC%9A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpwmxy87654%2Fattachments%2Fpwmxy87654%2Fwireless-connectivity%2540tkb%2F297%2F2%2FFRDM-KW36_48QFN_How_to_Measure_S11_20181114.pdf%22%20target%3D%22_self%22%3ERF%E3%83%9E%E3%83%83%E3%83%81%E3%83%B3%E3%82%B0%E3%81%AE%E3%83%AA%E3%82%BF%E3%83%BC%E3%83%B3%E3%83%AD%E3%82%B9%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%EF%BC%88S11%EF%BC%89%3C%2FA%3E%3C%2FP%3E%0A%3CP%3ERF%E3%83%AC%E3%83%9D%E3%83%BC%E3%83%88%EF%BC%88AN13728%EF%BC%89%E3%81%AE%E4%B8%80%E9%83%A8%3C%2FP%3E%0A%3CP%3E%E3%83%AD%E3%83%BC%E3%83%89%E3%83%97%E3%83%AB%3A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN13584.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EKinetis%20KW45%E3%81%8A%E3%82%88%E3%81%B3K32W148%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E3%83%97%E3%83%AB%E3%83%AC%E3%83%9D%E3%83%BC%E3%83%88%EF%BC%88nxp.com%EF%BC%89%3C%2FA%3E%20%3B%20%3CA%20id%3D%22relatedDocsClickHTML_2%22%20class%3D%22dtmcustomrulelink%22%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FAN14391%2Fpage%2Ftopics%2Fintroduction.html%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%20data-dtmaction%3D%22Documentation%20Section%20-%20Results%20Link%20Click%22%20data-dtmsubaction%3D%22MCX%20W71%20Loadpull%20Report%20-%20NXP%20-%20Application%20Note%20-%20English%22%3E%3CSPAN%3EMCX%20W71%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E3%83%97%E3%83%AB%E3%83%AC%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ESW%E3%83%84%E3%83%BC%E3%83%AB%3A%3C%2FP%3E%0A%3CP%3EIoT%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%EF%BC%88%E3%83%A2%E3%83%90%E3%82%A4%E3%83%AB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%E8%A3%BD%E5%93%81%E3%81%AE%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%E3%83%86%E3%82%B9%E3%83%88%E3%83%84%E3%83%BC%E3%83%AB%20(IoT%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AE%E4%B8%80%E9%83%A8)%3C%2FP%3E%0A%3CP%3EDTM%EF%BC%9A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FWireless-Connectivity%2FHow-to-use-the-HCI-bb-on-Kinetis-family-products-and-get-access%2Fm-p%2F1272092%23M11118%22%20target%3D%22_blank%22%3EHCI_bb%E3%82%92Kinetis%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E8%A3%BD%E5%93%81%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%20-%20NXP%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FWireless-Connectivity-Knowledge%2FBLE-HCI-Application-to-set-transmitter-receiver-test-commands%2Fta-p%2F1126093%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FWireless-Connectivity-Knowledge%2FBLE-HCI-Application-to-set-transmitter-...%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E%E7%B5%90%E6%99%B6%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E8%A8%98%E4%BA%8B1%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FWireless-Connectivity-Knowledge%2FKW45-K32W1-32MHz-amp-32kHz-Oscilllation-margins%2Fta-p%2F1692836%22%20target%3D%22_blank%22%3EKW45%2FK32W1%2032MHz%20%26amp%3B%2032kHz%20%E7%99%BA%E6%8C%AF%E3%83%9E%E3%83%BC%E3%82%B8%E3%83%B3%20-%20NXP%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E7%AC%AC2%E6%9D%A1%EF%BC%9A%3C%2FSPAN%3E%20%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Ftkb%2Fworkflowpage%2Ftkb-id%2Fwireless-connectivity%252540tkb%2Farticle-id%2F336%3Femcs_t%3DS2h8ZW1haWx8Y3dmX3RvcGljX3N1YnNjcmlwdGlvbnxMUlo2RzJURThWNTdHUnwxNjkyODM2fFNVQlNDUklQVElPTlN8aEs%22%20target%3D%22_blank%22%3EKW45%2FK32W1%2032MHz%E3%81%8A%E3%82%88%E3%81%B332kHz%E3%81%AE%E7%99%BA%E6%8C%AF%E3%83%9E%E3%83%BC%E3%82%B8%E3%83%B3%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CA%20title%3D%22FRO32k%22%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FAN14298%2Fpage%2Ftopics%2Fintroduction.html%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%3E32kHz%E6%B0%B4%E6%99%B6%E4%B8%8D%E8%A6%81%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Feur01.safelinks.protection.outlook.com%2F%3Furl%3Dhttps%253A%252F%252Fcommunity.nxp.com%252Ft5%252FWireless-Connectivity-Knowledge%252FKW36-Trimming-adjust-of-32MHz-XTAL-external-oscillator%252Fta-p%252F1112235%253Femcs_t%253DS2h8ZW1haWx8bWVzc2FnZV9zdWJzY3JpcHRpb258S1U0WU44WElVUVdRT1Z8MTM0ODAwNHxTVUJTQ1JJUFRJT05TfGhL%26amp%3Bdata%3D04%257C01%257Cchristopher.menard%2540nxp.com%257Ce57084d2e425490dda0d08d982fad7ef%257C686ea1d3bc2b4c6fa92cd99c5c301635%257C0%257C0%257C637684836140308780%257CUnknown%257CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%253D%257C1000%26amp%3Bsdata%3DXM6dOgZh5JzJ%252BhiVksVByCX8KG%252BmFbwY%252FGsWzebF8Ig%253D%26amp%3Breserved%3D0%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EKW36%20-%2032MHz%20XTAL%E5%A4%96%E9%83%A8%E7%99%BA%E6%8C%AF%E5%99%A8%E3%81%AE%E3%83%88%E3%83%AA%E3%83%9F%E3%83%B3%E3%82%B0%E8%AA%BF%E6%95%B4%20-%20NXP%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FWireless-Connectivity-Knowledge%2FKW45-MCX-W71-Trimming-adjust-of-32MHz-amp-32kHz-external%2Fta-p%2F1951277%22%20target%3D%22_blank%22%3EKW45%20%2F%20MCX%20W71%20-%2032MHz%E3%81%8A%E3%82%88%E3%81%B332kHz%E5%A4%96%E9%83%A8%E6%B0%B4%E6%99%B6%E6%8C%AF%E5%8B%95%E5%AD%90%E3%81%AE%E3%83%88%E3%83%AA%E3%83%9F%E3%83%B3%E3%82%B0%E8%AA%BF%E6%95%B4%20-%20NXP%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E%E4%BD%8E%E6%B6%88%E8%B2%BB%E9%9B%BB%E5%8A%9B%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E8%A6%8B%E7%A9%8D%E3%82%82%E3%82%8A%E3%83%84%E3%83%BC%E3%83%AB%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FWireless-Connectivity%2FKinetis-KW35-38-KW45-amp-K32W1-MCXW71-Power-Profile-Tool%2Fm-p%2F1830452%23M16886%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FWireless-Connectivity%2FKinetis-KW35-38-KW45-amp-K32W1-MCXW71-%E3%83%91%E3%83%AF%E3%83%BC%E3%83%97%E3%83%AD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%83%84%E3%83%BC%E3%83%AB%2Fmp%2F1830452%23M16886%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fnxp1.sharepoint.com%2F%3Ax%3A%2Fr%2Fsites%2FMCUlibrary%2Fkw47%2F03_Applications%2FPower%2520Consumption%2FKW45_WK47_MCXW71_MCXW72_BLE_power_profile_calculator_v1.34.xlsx%3Fd%3Dw87a48fa2ef0f41ca8f85e89189ff0290%26amp%3Bcsf%3D1%26amp%3Bweb%3D1%26amp%3Be%3DP1aESf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EKW45_WK47_MCXW71_MCXW72_BLE_%E9%9B%BB%E5%8A%9B%E3%83%97%E3%83%AD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E8%A8%88%E7%AE%97%E6%A9%9F_v1.34.xlsx%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fnxp1.sharepoint.com%2F%3Ax%3A%2Fr%2Fsites%2FMCUlibrary%2Fkw47%2F03_Applications%2FPower%2520Consumption%2FMCX%2520W7x%2520802.15.4%2520Matter%2520ICD%2520SIT%2520LIT%2520%2526%2520ZED%2520Power%2520profile%2520v0.6.xlsx%3Fd%3Dwdebcbf8b355d4537aeb8470c54463100%26amp%3Bcsf%3D1%26amp%3Bweb%3D1%26amp%3Be%3D72OFNs%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EMCX%20W7x%20802.15.4%20%E3%83%9E%E3%82%BF%E3%83%BC%20ICD%20SIT%20LIT%20%26amp%3B%20ZED%20%E9%9B%BB%E6%BA%90%E3%83%97%E3%83%AD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20v0.6.xlsx%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E4%BD%8E%E6%B6%88%E8%B2%BB%E9%9B%BB%E5%8A%9B%3A%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN13230.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN13230.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CA%20id%3D%22relatedDocsClickHTML_3%22%20class%3D%22dtmcustomrulelink%22%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FAN14389%2Fpage%2Ftopics%2Fintroduction.html%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%20data-dtmaction%3D%22Documentation%20Section%20-%20Results%20Link%20Click%22%20data-dtmsubaction%3D%22MCX%20W71%20Bluetooth%20LE%20Power%20Consumption%20Analysis%20-%20NXP%20-%20Application%20Note%20-%20English%22%3E%3CSPAN%3E%3CU%3E%26nbsp%3B%20%26nbsp%3B%3C%2FU%3EMCX%20W71%20Bluetooth%20LE%20%E6%B6%88%E8%B2%BB%E9%9B%BB%E5%8A%9B%E5%88%86%E6%9E%90%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fnxp1.sharepoint.com%2F%3Ab%3A%2Fr%2Fsites%2FMCUlibrary%2Fkw47%2F03_Applications%2FPower%2520Consumption%2FAN%2520MCX%2520W72%2520802.15.4%2520Matter%2520and%2520Zigbee%2520Power%2520profile%2520analysis.pdf%3Fcsf%3D1%26amp%3Bweb%3D1%26amp%3Be%3Dk9cOCj%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAN%20MCX%20W72%20802.15.4%20%E3%83%9E%E3%82%BF%E3%83%BC%E3%81%8A%E3%82%88%E3%81%B3ZigBee%E9%9B%BB%E5%8A%9B%E3%83%97%E3%83%AD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%88%86%E6%9E%90.pdf%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E8%AA%8D%E8%A8%BC%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CTABLE%20class%3D%22wrapped%20confluenceTable%20tablesorter%20tablesorter-default%20stickyTableHeaders%22%20role%3D%22grid%22%20data-fm-marker%3D%22964%22%3E%0A%3CTBODY%20data-fm-marker%3D%22968%22%3E%0A%3CTR%20role%3D%22row%22%20data-fm-marker%3D%22972%22%3E%0A%3CTD%20class%3D%22confluenceTd%22%20data-fm-marker%3D%22973%22%3E%0A%3CP%20data-fm-marker%3D%22974%22%3EKW45%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20class%3D%22confluenceTd%22%20data-fm-marker%3D%22975%22%3E%0A%3CP%20data-fm-marker%3D%22976%22%3E%3CA%20class%3D%22external-link%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Freliability-and-quality-information%2FREDMD3313501.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20data-fm-marker%3D%22977%22%3EKW45B41Z-EVK%20%E8%A9%95%E4%BE%A1%E3%82%AD%E3%83%83%E3%83%88%E3%81%AE%E6%AC%A7%E5%B7%9E%E9%80%A3%E5%90%88%E9%81%A9%E5%90%88%E5%AE%A3%E8%A8%80%3C%2FA%3E%3C%2FP%3E%0A%3CP%20data-fm-marker%3D%22978%22%3E%3CA%20class%3D%22external-link%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Freliability-and-quality-information%2FREDPART00000057401.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20data-fm-marker%3D%22979%22%3EKW45B41Z-LOC%20%E3%81%AE%E6%AC%A7%E5%B7%9E%E9%80%A3%E5%90%88%E9%81%A9%E5%90%88%E5%AE%A3%E8%A8%80%3C%2FA%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20role%3D%22row%22%20data-fm-marker%3D%22980%22%3E%0A%3CTD%20class%3D%22confluenceTd%22%20data-fm-marker%3D%22981%22%3EK32W148%3C%2FTD%3E%0A%3CTD%20class%3D%22confluenceTd%22%20data-fm-marker%3D%22982%22%3E%0A%3CP%20data-fm-marker%3D%22983%22%3E%3CA%20class%3D%22external-link%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Freliability-and-quality-information%2FREDMD1386701.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20data-fm-marker%3D%22984%22%3EK32W148-EVK%20%E8%A9%95%E4%BE%A1%E3%82%AD%E3%83%83%E3%83%88%E3%81%AE%E6%AC%A7%E5%B7%9E%E9%80%A3%E5%90%88%E9%81%A9%E5%90%88%E5%AE%A3%E8%A8%80%3C%2FA%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1592481%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3E%E8%A3%BD%E5%93%81%3A%20K32W1%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%EF%BC%9A802.15.4%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%EF%BC%9ABLE%E2%86%92%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%EF%BC%9ABluetooth%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%EF%BC%9AMatter%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%EF%BC%9AThread%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%EF%BC%9AZigbee%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1788390%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20best%20way%20to%20build%20a%20PCB%20using%20a%20KW45%20(car%20access)%20or%20K32W1%20(IoT%2FIndustrial)%20first%20time%20right%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1788390%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F139010%22%20target%3D%22_blank%22%3E%40christophe_menard%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3E%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AB%E3%81%AF%E3%80%81%E5%A4%96%E9%83%A8%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%81%AE%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%8C%20OTA%20%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%BE%8C%E3%81%AE%E6%89%80%E8%A6%81%E6%99%82%E9%96%93%E3%81%8C%E6%95%B0%E7%A7%92%E3%81%AB%E9%81%94%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E5%A4%96%E9%83%A8%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%81%8B%E3%82%89%E3%81%AE%E7%89%B9%E5%88%A5%E3%81%AA%E6%B3%A8%E6%84%8F%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1775325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20best%20way%20to%20build%20a%20PCB%20using%20a%20KW45%20(car%20access)%20or%20K32W1%20(IoT%2FIndustrial)%20first%20time%20right%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1775325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%A1%E3%83%8A%E3%83%BC%E3%83%89%E6%A7%98%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1774869%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20best%20way%20to%20build%20a%20PCB%20using%20a%20KW45%20(car%20access)%20or%20K32W1%20(IoT%2FIndustrial)%20first%20time%20right%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1774869%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81Suleymansekerci%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E3%20%E3%81%A4%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%20(PMIC%E3%80%81DCDC%E3%80%81%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9)%20%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%81%94%E8%A6%81%E6%9C%9B%E3%82%92%E8%A9%B3%E3%81%97%E3%81%8F%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%E3%81%94%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%81NXP%20%E3%82%B5%E3%82%A4%E3%83%88%E3%81%A7%E5%85%A5%E6%89%8B%E5%8F%AF%E8%83%BD%E3%81%AA%20AN13230%20Kinetis%20KW45%20%26amp%3B%20K32W1%20Bluetooth%20LE%20%E9%9B%BB%E5%8A%9B%E6%B6%88%E8%B2%BB%E5%88%86%E6%9E%90%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%80%81KW45_BLE_power_profile_calculator_v1.5.xlsx%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%93%8D%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%E3%81%94%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%81%E6%9C%80%E3%82%82%E5%AE%89%E5%85%A8%E3%81%AA%E9%9B%BB%E6%BA%90%E3%81%AF%E3%80%81%E8%BF%BD%E5%8A%A0%E3%81%AE%20BoM%20%E3%82%B3%E3%82%B9%E3%83%88%E3%81%8C%E3%81%8B%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E9%99%8D%E5%9C%A7%E3%83%A2%E3%83%BC%E3%83%89%20(Kinetis%20%E8%A3%BD%E5%93%81%E5%86%85%E9%83%A8%E3%81%AE%20DCDC)%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1774600%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20best%20way%20to%20build%20a%20PCB%20using%20a%20KW45%20(car%20access)%20or%20K32W1%20(IoT%2FIndustrial)%20first%20time%20right%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1774600%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EKW54%20%E3%81%AE%203%20%E3%81%A4%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%20(PMIC%E3%80%81DCDC%E3%80%81%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9)%20%E3%81%A7%E3%81%AE%E6%B6%88%E8%B2%BB%E9%9B%BB%E5%8A%9B%E3%81%AE%E5%80%A4%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E8%AA%B0%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1628877%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20best%20way%20to%20build%20a%20PCB%20using%20a%20KW45%20(car%20access)%20or%20K32W1%20(IoT%2FIndustrial)%20first%20time%20right%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1628877%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%9E%E3%83%AB%E3%82%B3%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%81%AF%203%20%E3%81%A4%E3%81%AECASE%E3%81%A7%E5%90%8C%E3%81%98%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1628875%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20best%20way%20to%20build%20a%20PCB%20using%20a%20KW45%20(car%20access)%20or%20K32W1%20(IoT%2FIndustrial)%20first%20time%20right%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1628875%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%9E%E3%83%AB%E3%82%B3%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E5%80%A4%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%81%AF%203%20%E3%81%A4%E3%81%AECASE%E3%81%A7%E5%90%8C%E3%81%98%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1628765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20best%20way%20to%20build%20a%20PCB%20using%20a%20KW45%20(car%20access)%20or%20K32W1%20(IoT%2FIndustrial)%20first%20time%20right%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1628765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E3%80%8C%E6%9C%80%E5%B0%8F%20BOM%E3%80%8D%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%9C%80%E5%BE%8C%E3%81%AB%E3%80%81%E3%82%B3%E3%83%B3%E3%82%BB%E3%83%AB%E6%93%8D%E4%BD%9C%E3%81%AE%E6%8E%A8%E5%A5%A8%E4%BA%8B%E9%A0%85%E3%82%92%E7%A4%BA%E3%81%99%E8%A1%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22marko_pavlin_1-1680760460835.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22marko_pavlin_1-1680760460835.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22marko_pavlin_1-1680760460835.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F217998iEA231C1A848459E3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22marko_pavlin_1-1680760460835.png%22%20alt%3D%22marko_pavlin_1-1680760460835.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E5%A4%A7%E4%B8%88%E5%A4%AB%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F10dBm%20%26lt%3B1mA%E3%80%81...%200dBm%20%3A%204%2C5mA%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
