* MODULE: ControlBridge
* COMPONENT: zcl_options.h
* AUTHOR: Faisal Bhaiyat
* DESCRIPTION: Options Header for ZigBee Cluster Library functions
* $HeadURL: https://www.collabnet.nxp.com/svn/lprf_sware/Projects/Zigbee%20Protocol%20Stack/ZPS/Trunk/ControlBridge/Source/ControlBridge/zcl_options.h $
* $Revision: 54776 $
* $LastChangedBy: nxp29741 $
* $LastChangedDate: 2013-06-20 11:50:33 +0100 (Thu, 20 Jun 2013) $
* $Id: zcl_options.h 54776 2013-06-20 10:50:33Z nxp29741 $
* This software is owned by NXP B.V. and/or its supplier and is protected
* under applicable copyright laws. All rights are reserved. We grant You,
* and any third parties, a license to use this software solely and
* exclusively on NXP products [NXP Microcontrollers such as JN5168, JN5164,
* JN5161, JN5148, JN5142, JN5139].
* You, and any third parties must reproduce the copyright and warranty notice
* and any other legend of ownership on each copy or partial copy of the
* software.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
* POSSIBILITY OF SUCH DAMAGE.
* Copyright NXP B.V. 2012. All rights reserved
#ifndef ZCL_OPTIONS_H
#define ZCL_OPTIONS_H
#include <jendefs.h>
/*** Macro Definitions ***/
#define ZCL_ALLOW_WILD_CARD_PROFILE
#define CLD_BAS_CMD_RESET_TO_FACTORY_DEFAULTS
/* Set this True to disable non error default responses from clusters */
#define ZCL_DISABLE_DEFAULT_RESPONSES (TRUE)
#define ZCL_DISABLE_APS_ACK (FALSE)
#define OTA_ACKS_ON (FALSE)
#define OTA_CLIENT_DISABLE_DEFAULT_RESPONSE (TRUE)
// Total number of group addresses required by all sub-device endpoints on the device
#define GROUPS_REQUIRED ( 16 )
#define CLD_GROUPS_MAX_NUMBER_OF_GROUPS ( 16 )
/* Sets the number of endpoints that will be created by the ZCL library */
#define ZCL_NUMBER_OF_ENDPOINTS ( 5 )
#define ZCL_NUMBER_DEVICES ( 5 )
#define ZLO_NUMBER_DEVICES (5)
#define ZCL_MANUFACTURER_CODE ( 0x1037 )
#define APPLICATION_DEVICE_VERSION ( 2 )
/* For GP proxy cluster*/
#define ZCL_NUMBER_OF_APPLICATION_TIMERS ( 5 )
#define TL_LEGACY_PROFILE_ID ( 0xc05e )
#define TL_LEGACY_DEVICE_ID ( 0x0840 )
#define TL_LEGACY_VERSION_ID ( 2 )
#define ZCL_ATTRIBUTE_DISCOVERY_SERVER_SUPPORTED
#define ZCL_ATTRIBUTE_DISCOVERY_CLIENT_SUPPORTED
#define ZCL_ATTRIBUTE_DISCOVERY_EXTENDED_SERVER_SUPPORTED
#define ZCL_ATTRIBUTE_DISCOVERY_EXTENDED_CLIENT_SUPPORTED
#define ZCL_COMMAND_DISCOVERY_SUPPORTED
#define ZCL_COMMAND_RECEIVED_DISCOVERY_SERVER_SUPPORTED
#define ZCL_COMMAND_RECEIVED_DISCOVERY_CLIENT_SUPPORTED
#define ZCL_COMMAND_GENERATED_DISCOVERY_SERVER_SUPPORTED
#define ZCL_COMMAND_GENERATED_DISCOVERY_CLIENT_SUPPORTED
/* Clusters used by this application */
#define CLD_BASIC
#define BASIC_SERVER
#define BASIC_CLIENT
#ifdef FULL_FUNC_DEVICE
#define CLD_ZLL_COMMISSION
#define ZLL_COMMISSION_CLIENT
#define ZLL_COMMISSION_SERVER
#define CLD_ZLL_UTILITY
#define ZLL_UTILITY_SERVER
#define ZLL_UTILITY_CLIENT
#endif
#define CLD_IDENTIFY
#define CLD_IDENTIFY_CMD_TRIGGER_EFFECT
#define IDENTIFY_CLIENT
#define IDENTIFY_SERVER
#define CLD_IDENTIFY_TICKS_PER_SECOND 10
#define CLD_IDENTIFY_SUPPORT_ZLL_ENHANCED_COMMANDS
#define CLD_GROUPS
#define GROUPS_CLIENT
#define GROUPS_SERVER
#define CLD_ONOFF
#define CLD_ONOFF_CMD_OFF_WITH_EFFECT
#define CLD_ONOFF_CMD_ON_WITH_TIMED_OFF
#define ONOFF_CLIENT
#define ONOFF_SERVER
#define CLD_ONOFF_SUPPORT_ZLL_ENHANCED_COMMANDS
#define CLD_LEVEL_CONTROL
#define LEVEL_CONTROL_CLIENT
#define CLD_LEVELCONTROL_TICKS_PER_SECOND 10
#define CLD_SCENES
#define SCENES_CLIENT
#define CLD_COLOUR_CONTROL
#define COLOUR_CONTROL_CLIENT
#define CLD_IASZONE
#define IASZONE_CLIENT
#define CLD_SIMPLE_METERING
#define SM_CLIENT
#define CLD_DIAGNOSTICS
#define DIAGNOSTICS_CLIENT
#define CLD_DIAGNOSTICS_ATTR_ID_AVERAGE_MAC_RETRY_PER_APS_MESSAGE_SENT
#define CLD_DIAGNOSTICS_ATTR_ID_LAST_MESSAGE_LQI
#define CLD_DIAGNOSTICS_ATTR_ID_LAST_MESSAGE_RSSI
#define CLD_OTA
#define OTA_SERVER
#define OTA_MAX_BLOCK_SIZE 64
#define OTA_TIME_INTERVAL_BETWEEN_RETRIES 5
#define OTA_MAX_IMAGES_PER_ENDPOINT 1
#define OTA_CLD_ATTR_CURRENT_FILE_VERSION
#define OTA_MAX_CO_PROCESSOR_IMAGES 1
#define NUM_ENDPOINT_RECORDS 20
#define NUM_GROUP_RECORDS 16
/* Enable reports to be configured on remote servers and responses to be received */
#define ZCL_CONFIGURE_ATTRIBUTE_REPORTING_CLIENT_SUPPORTED
#define ZCL_ATTRIBUTE_REPORTING_CLIENT_SUPPORTED
#define ZCL_READ_ATTRIBUTE_REPORTING_CONFIGURATION_CLIENT_SUPPORTED
/* Basic Cluster - Optional Attributes */
/* Add the following #define's to your zcl_options.h file to add optional */
/* attributes to the basic cluster. */
#define ZCL_ATTRIBUTE_READ_SERVER_SUPPORTED
#define ZCL_ATTRIBUTE_READ_CLIENT_SUPPORTED
#define ZCL_ATTRIBUTE_WRITE_SERVER_SUPPORTED
#define ZCL_ATTRIBUTE_WRITE_CLIENT_SUPPORTED
//#define CLD_BAS_ATTR_LOCATION_DESCRIPTION
//#define CLD_BAS_ATTR_PHYSICAL_ENVIRONMENT
//#define CLD_BAS_ATTR_DEVICE_ENBLED
//#define CLD_BAS_ATTR_ALARM_MASK
#define CLD_BAS_ATTR_APPLICATION_VERSION
#define CLD_BAS_ATTR_STACK_VERSION
#define CLD_BAS_ATTR_HARDWARE_VERSION
#define CLD_BAS_ATTR_MANUFACTURER_NAME
#define CLD_BAS_ATTR_MODEL_IDENTIFIER
#define CLD_BAS_ATTR_DATE_CODE
#define CLD_BAS_ATTR_SW_BUILD_ID
#define CLD_BAS_ATTR_CONFIG_MODEL_IDENTIFIER
#define CLD_BAS_APP_VERSION (1)
#define CLD_BAS_STACK_VERSION (1)
#define CLD_BAS_HARDWARE_VERSION (1)
#define CLD_BAS_MANUF_NAME_SIZE (3)
#define CLD_BAS_MODEL_ID_SIZE (17)
#define CLD_BAS_DATE_SIZE (8)
#define CLD_BAS_POWER_SOURCE E_CLD_BAS_PS_BATTERY
#define CLD_BAS_SW_BUILD_SIZE (9)
#define CLD_BAS_CONFIG_MODEL_ID_SIZE CLD_BAS_MODEL_ID_SIZE
*//* Green Power Cluster - Optional Attributes *//*
*//* Add the following #define's to your zcl_options.h file to add optional *//*
*//* attributes to the Green Power cluster. *//*
#ifdef CLD_GREENPOWER
#define GP_IEEE_ADDR_SUPPORT
#define GREENPOWER_END_POINT_ID 2
#define GP_NUMBER_OF_TRANSLATION_TABLE_ENTRIES 5
#define GP_NUMBER_OF_PROXY_SINK_TABLE_ENTRIES 5
#define CLD_GP_ATTR_ZGPS_COMMISSIONING_WINDOW
#define CLD_GP_ATTR_ZGP_SHARED_SECURITY_KEY_TYPE
#define CLD_GP_ATTR_ZGP_LINK_KEY
*//* security level *//*
#define GP_SECURITY_LEVEL E_GP_ENC_FULL_FC_FULL_MIC
*//* Possible values are E_GP_NO_KEY, E_GP_ZIGBEE_NWK_KEY, E_GP_ZGPD_GROUP_KEY,
E_GP_NWK_KEY_DERIVED_ZGPD_GROUP_KEY, E_GP_OUT_OF_THE_BOX_ZGPD_KEY, E_GP_DERIVED_INDIVIDUAL_ZGPD_KEY*//*
#define GP_KEYTPE E_GP_ZGPD_GROUP_KEY
#define GP_SHARED_KEY { 0xC0 , 0xC1 , 0xC2 , 0xC3 , 0xC4 , 0xC5 , 0xC6 , 0xC7 , 0xC8 , 0xC9 , 0xCa , 0xCb , 0xCc , 0xCd , 0xCe , 0xCf}
#undef ZCL_NUMBER_OF_ENDPOINTS
#define ZCL_NUMBER_OF_ENDPOINTS 2
#undef CLD_GROUPS_MAX_NUMBER_OF_GROUPS
#define CLD_GROUPS_MAX_NUMBER_OF_GROUPS 4
#define GP_MAX_TRANS_ZB_CMD_PAYLOAD_LENGTH 2
#endif*/
/* Colour Control Cluster - Optional Attributes */
/* attributes to the time cluster. */
* Colour attributes, Optional in ZCL spec but Mandatory for ZLL
/* Colour information attribute set attribute ID's (5.2.2.2.1) */
#define CLD_COLOURCONTROL_ATTR_CURRENT_HUE
#define CLD_COLOURCONTROL_ATTR_CURRENT_SATURATION
#define CLD_COLOURCONTROL_ATTR_REMAINING_TIME
#define CLD_COLOURCONTROL_ATTR_COLOUR_MODE
#define CLD_COLOURCONTROL_ATTR_COLOUR_TEMPERATURE
//#define SCENES_SERVER
/* Defined Primaries Information attribute attribute ID's set (5.2.2.2.2) */
#define CLD_COLOURCONTROL_ATTR_NUMBER_OF_PRIMARIES 3
/* Enable Primary (n) X, Y and Intensity attributes */
#define CLD_COLOURCONTROL_ATTR_PRIMARY_1
#define CLD_COLOURCONTROL_ATTR_PRIMARY_2
#define CLD_COLOURCONTROL_ATTR_PRIMARY_3
#define CLD_COLOURCONTROL_ATTR_PRIMARY_4
#define CLD_COLOURCONTROL_ATTR_PRIMARY_5
#define CLD_COLOURCONTROL_ATTR_PRIMARY_6
/* ZLL enhanced attributes */
#define CLD_COLOURCONTROL_ATTR_ENHANCED_CURRENT_HUE
#define CLD_COLOURCONTROL_ATTR_ENHANCED_COLOUR_MODE
#define CLD_COLOURCONTROL_ATTR_COLOUR_LOOP_ACTIVE
#define CLD_COLOURCONTROL_ATTR_COLOUR_LOOP_DIRECTION
#define CLD_COLOURCONTROL_ATTR_COLOUR_LOOP_TIME
#define CLD_COLOURCONTROL_ATTR_COLOUR_LOOP_START_ENHANCED_HUE
#define CLD_COLOURCONTROL_ATTR_COLOUR_LOOP_STORED_ENHANCED_HUE
#define CLD_COLOURCONTROL_ATTR_COLOUR_CAPABILITIES
#define CLD_COLOURCONTROL_ATTR_COLOUR_TEMPERATURE_PHY_MIN
#define CLD_COLOURCONTROL_ATTR_COLOUR_TEMPERATURE_PHY_MAX
#define CLD_COLOURCONTROL_ATTR_COLOUR_TEMPERATURE_MIRED
/* Max & Min Limits for colour temperature */
#define CLD_COLOURCONTROL_COLOUR_TEMPERATURE_PHY_MIN 0x0001
#define CLD_COLOURCONTROL_COLOUR_TEMPERATURE_PHY_MAX 0xfef8
#define CLD_COLOURCONTROL_RED_X (0.68)
#define CLD_COLOURCONTROL_RED_Y (0.31)
#define CLD_COLOURCONTROL_GREEN_X (0.11)
#define CLD_COLOURCONTROL_GREEN_Y (0.82)
#define CLD_COLOURCONTROL_BLUE_X (0.13)
#define CLD_COLOURCONTROL_BLUE_Y (0.04)
#define CLD_COLOURCONTROL_WHITE_X (0.33)
#define CLD_COLOURCONTROL_WHITE_Y (0.33)
#define CLD_COLOURCONTROL_PRIMARY_1_X CLD_COLOURCONTROL_RED_X
#define CLD_COLOURCONTROL_PRIMARY_1_Y CLD_COLOURCONTROL_RED_Y
#define CLD_COLOURCONTROL_PRIMARY_1_INTENSITY (254 / 3)
#define CLD_COLOURCONTROL_PRIMARY_2_X CLD_COLOURCONTROL_GREEN_X
#define CLD_COLOURCONTROL_PRIMARY_2_Y CLD_COLOURCONTROL_GREEN_Y
#define CLD_COLOURCONTROL_PRIMARY_2_INTENSITY (254 / 3)
#define CLD_COLOURCONTROL_PRIMARY_3_X CLD_COLOURCONTROL_BLUE_X
#define CLD_COLOURCONTROL_PRIMARY_3_Y CLD_COLOURCONTROL_BLUE_Y
#define CLD_COLOURCONTROL_PRIMARY_3_INTENSITY (254 / 3)
#define CLD_COLOURCONTROL_PRIMARY_4_X (0)
#define CLD_COLOURCONTROL_PRIMARY_4_Y (0)
#define CLD_COLOURCONTROL_PRIMARY_4_INTENSITY (0xff)
#define CLD_COLOURCONTROL_PRIMARY_5_X (0)
#define CLD_COLOURCONTROL_PRIMARY_5_Y (0)
#define CLD_COLOURCONTROL_PRIMARY_5_INTENSITY (0xff)
#define CLD_COLOURCONTROL_PRIMARY_6_X (0)
#define CLD_COLOURCONTROL_PRIMARY_6_Y (0)
#define CLD_COLOURCONTROL_PRIMARY_6_INTENSITY (0xff)
#define CLD_COLOUR_CONTROL_SUPPORT_ZLL_ENHANCED_COMMANDS
#define CLD_COLOUR_CONTROL_SUPPORT_ZLL_COLOUR_TEMPERATURE_COMMANDS
/* ZLL attribute in on off cluster */
//#define CLD_ONOFF_ATTR_GLOBAL_SCENE_CONTROL
//#define CLD_ONOFF_ATTR_ON_TIME
//#define CLD_ONOFF_ATTR_OFF_WAIT_TIME
#define ZLL_DISABLE_DEFAULT_RESPONSES FALSE
/* WARNING -- Need to setup bugger apdus and fragmentation to enable ASC */
//#define CLD_ASC_LOG
#define CLD_DOOR_LOCK
#define DOOR_LOCK_CLIENT
#define CLD_THERMOSTAT
#define THERMOSTAT_CLIENT
#define CLD_TEMPERATURE_MEASUREMENT
#define TEMPERATURE_MEASUREMENT_CLIENT
#define CLD_RELATIVE_HUMIDITY_MEASUREMENT
#define RELATIVE_HUMIDITY_MEASUREMENT_CLIENT
#define CLD_ILLUMINANCE_MEASUREMENT
#define ILLUMINANCE_MEASUREMENT_CLIENT
//#define CLD_APPLIANCE_STATISTICS
//#define APPLIANCE_STATISTICS_SERVER
//#define APPLIANCE_STATISTICS_CLIENT
#define CLD_SM_ATTR_INSTANTANEOUS_DEMAND
/*** Type Definitions ***/
/*** Exported Functions ***/
PUBLIC void* psGetDeviceTable(void);
/*** External Variables ***/
/*** END OF FILE ***/
#endif /* ZCL_OPTIONS_H */
* software.
#define CLD_BASIC
#endif
#define CLD_GROUPS
#define CLD_ONOFF
#define CLD_SCENES
#define CLD_IASZONE
#define SM_CLIENT
#define CLD_OTA
#define OTA_SERVER
#endif*/
