Some Endpoints (id>2) not getting commands sent to Endpoint 255 and group address
11,313 次查看
dmsherazi
I am adding few more endoints to the JN-AN-1247 Control bridge for zigbee 3.0 based on JN5189.
I am adding ON/OFF Light on the three endpoints 2,3,4 , keeping the 1st endpoint as control bridge.
I would be using the control bridge as a Full_Function_Router device.
Everything so far is OK except that when I send any command using group id or  Broadcast EP 255  the Endpoint above 2 doesnt recieve it!
So an ON command to EP 255  will result in switiing ON on Ep 1and 2 but not on 3 or 4. Strangely when sent to EP 3 or 4 it will switch on the relevant Light. I am not sure where is the issue and how to get its cause.
What I have done so far
  1. Took AN-JN-1247 as initial device
  2. Configured the ControlBridge_Full.zpscfg to add the new endpoints with input and output clutsres as below
  3. Modified the Zcl_options.h to reflect the above
破坏者
 * MODULE:             ControlBridge
 * COMPONENT:          zcl_options.h
 * AUTHOR:             Faisal Bhaiyat
 * DESCRIPTION:        Options Header for ZigBee Cluster Library functions
 * $HeadURL: https://www.collabnet.nxp.com/svn/lprf_sware/Projects/Zigbee%20Protocol%20Stack/ZPS/Trunk/ControlBridge/Source/ControlBridge/zcl_options.h $
 * $Revision: 54776 $
 * $LastChangedBy: nxp29741 $
 * $LastChangedDate: 2013-06-20 11:50:33 +0100 (Thu, 20 Jun 2013) $
 * $Id: zcl_options.h 54776 2013-06-20 10:50:33Z nxp29741 $
 * This software is owned by NXP B.V. and/or its supplier and is protected
 * under applicable copyright laws. All rights are reserved. We grant You,
 * and any third parties, a license to use this software solely and
 * exclusively on NXP products [NXP Microcontrollers such as JN5168, JN5164,
 * JN5161, JN5148, JN5142, JN5139].
 * You, and any third parties must reproduce the copyright and warranty notice
 * and any other legend of ownership on each copy or partial copy of the
 * software.
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
 * POSSIBILITY OF SUCH DAMAGE.
 * Copyright NXP B.V. 2012. All rights reserved
#ifndef ZCL_OPTIONS_H
#define ZCL_OPTIONS_H
#include <jendefs.h>
/***        Macro Definitions                                             ***/
#define ZCL_ALLOW_WILD_CARD_PROFILE
#define CLD_BAS_CMD_RESET_TO_FACTORY_DEFAULTS
/* Set this True to disable non error default responses from clusters */
#define ZCL_DISABLE_DEFAULT_RESPONSES                      (TRUE)
#define ZCL_DISABLE_APS_ACK                                (FALSE)
#define OTA_ACKS_ON                                        (FALSE)
#define OTA_CLIENT_DISABLE_DEFAULT_RESPONSE                (TRUE)
// Total number of group addresses required by all sub-device endpoints on the device
#define GROUPS_REQUIRED                                     ( 16 )
#define CLD_GROUPS_MAX_NUMBER_OF_GROUPS                     ( 16  )
/* Sets the number of endpoints that will be created by the ZCL library */
#define ZCL_NUMBER_OF_ENDPOINTS                             ( 5 )
#define ZCL_NUMBER_DEVICES                                  ( 5 )
#define ZLO_NUMBER_DEVICES                                  (5)
#define ZCL_MANUFACTURER_CODE                               ( 0x1037 )
#define APPLICATION_DEVICE_VERSION                               ( 2 )
/* For GP proxy cluster*/
#define ZCL_NUMBER_OF_APPLICATION_TIMERS                    ( 5 )
#define TL_LEGACY_PROFILE_ID                                ( 0xc05e )
#define TL_LEGACY_DEVICE_ID                                 ( 0x0840 )
#define TL_LEGACY_VERSION_ID                                ( 2 )
#define ZCL_ATTRIBUTE_DISCOVERY_SERVER_SUPPORTED
#define ZCL_ATTRIBUTE_DISCOVERY_CLIENT_SUPPORTED
#define ZCL_ATTRIBUTE_DISCOVERY_EXTENDED_SERVER_SUPPORTED
#define ZCL_ATTRIBUTE_DISCOVERY_EXTENDED_CLIENT_SUPPORTED
#define ZCL_COMMAND_DISCOVERY_SUPPORTED
#define ZCL_COMMAND_RECEIVED_DISCOVERY_SERVER_SUPPORTED
#define ZCL_COMMAND_RECEIVED_DISCOVERY_CLIENT_SUPPORTED
#define ZCL_COMMAND_GENERATED_DISCOVERY_SERVER_SUPPORTED
#define ZCL_COMMAND_GENERATED_DISCOVERY_CLIENT_SUPPORTED
/* Clusters used by this application */
#define CLD_BASIC
#define BASIC_SERVER
#define BASIC_CLIENT
#ifdef FULL_FUNC_DEVICE
#define CLD_ZLL_COMMISSION
#define ZLL_COMMISSION_CLIENT
#define ZLL_COMMISSION_SERVER
#define CLD_ZLL_UTILITY
#define ZLL_UTILITY_SERVER
#define ZLL_UTILITY_CLIENT
#endif
#define CLD_IDENTIFY
#define CLD_IDENTIFY_CMD_TRIGGER_EFFECT
#define IDENTIFY_CLIENT
#define IDENTIFY_SERVER
#define CLD_IDENTIFY_TICKS_PER_SECOND   10
#define CLD_IDENTIFY_SUPPORT_ZLL_ENHANCED_COMMANDS
#define CLD_GROUPS
#define GROUPS_CLIENT
#define GROUPS_SERVER
#define CLD_ONOFF
#define CLD_ONOFF_CMD_OFF_WITH_EFFECT
#define CLD_ONOFF_CMD_ON_WITH_TIMED_OFF
#define ONOFF_CLIENT
#define ONOFF_SERVER
#define CLD_ONOFF_SUPPORT_ZLL_ENHANCED_COMMANDS
#define CLD_LEVEL_CONTROL
#define LEVEL_CONTROL_CLIENT
#define CLD_LEVELCONTROL_TICKS_PER_SECOND                   10
#define CLD_SCENES
#define SCENES_CLIENT
#define CLD_COLOUR_CONTROL
#define COLOUR_CONTROL_CLIENT
#define CLD_IASZONE
#define IASZONE_CLIENT
#define CLD_SIMPLE_METERING
#define SM_CLIENT
#define CLD_DIAGNOSTICS
#define DIAGNOSTICS_CLIENT
#define CLD_DIAGNOSTICS_ATTR_ID_AVERAGE_MAC_RETRY_PER_APS_MESSAGE_SENT
#define CLD_DIAGNOSTICS_ATTR_ID_LAST_MESSAGE_LQI
#define CLD_DIAGNOSTICS_ATTR_ID_LAST_MESSAGE_RSSI
#define CLD_OTA
#define OTA_SERVER
#define OTA_MAX_BLOCK_SIZE                                    64
#define OTA_TIME_INTERVAL_BETWEEN_RETRIES                     5
#define OTA_MAX_IMAGES_PER_ENDPOINT                           1
#define OTA_CLD_ATTR_CURRENT_FILE_VERSION
#define OTA_MAX_CO_PROCESSOR_IMAGES                           1
#define NUM_ENDPOINT_RECORDS                                  20
#define NUM_GROUP_RECORDS                                     16
/* Enable reports to be configured on remote servers and responses to be received */
#define ZCL_CONFIGURE_ATTRIBUTE_REPORTING_CLIENT_SUPPORTED
#define ZCL_ATTRIBUTE_REPORTING_CLIENT_SUPPORTED
#define ZCL_READ_ATTRIBUTE_REPORTING_CONFIGURATION_CLIENT_SUPPORTED
/*             Basic Cluster - Optional Attributes                          */
/* Add the following #define's to your zcl_options.h file to add optional   */
/* attributes to the basic cluster.                                         */
#define ZCL_ATTRIBUTE_READ_SERVER_SUPPORTED
#define ZCL_ATTRIBUTE_READ_CLIENT_SUPPORTED
#define ZCL_ATTRIBUTE_WRITE_SERVER_SUPPORTED
#define ZCL_ATTRIBUTE_WRITE_CLIENT_SUPPORTED
//#define   CLD_BAS_ATTR_LOCATION_DESCRIPTION
//#define   CLD_BAS_ATTR_PHYSICAL_ENVIRONMENT
//#define   CLD_BAS_ATTR_DEVICE_ENBLED
//#define   CLD_BAS_ATTR_ALARM_MASK
#define CLD_BAS_ATTR_APPLICATION_VERSION
#define CLD_BAS_ATTR_STACK_VERSION
#define CLD_BAS_ATTR_HARDWARE_VERSION
#define CLD_BAS_ATTR_MANUFACTURER_NAME
#define CLD_BAS_ATTR_MODEL_IDENTIFIER
#define CLD_BAS_ATTR_DATE_CODE
#define CLD_BAS_ATTR_SW_BUILD_ID
#define CLD_BAS_ATTR_CONFIG_MODEL_IDENTIFIER
#define CLD_BAS_APP_VERSION             (1)
#define CLD_BAS_STACK_VERSION           (1)
#define CLD_BAS_HARDWARE_VERSION        (1)
#define CLD_BAS_MANUF_NAME_SIZE         (3)
#define CLD_BAS_MODEL_ID_SIZE           (17)
#define CLD_BAS_DATE_SIZE               (8)
#define CLD_BAS_POWER_SOURCE            E_CLD_BAS_PS_BATTERY
#define CLD_BAS_SW_BUILD_SIZE           (9)
#define CLD_BAS_CONFIG_MODEL_ID_SIZE    CLD_BAS_MODEL_ID_SIZE
*//*             Green Power Cluster - Optional Attributes                 *//*
*//* Add the following #define's to your zcl_options.h file to add optional   *//*
*//* attributes to the Green Power cluster.                                          *//*
#ifdef  CLD_GREENPOWER
    #define GP_IEEE_ADDR_SUPPORT
    #define GREENPOWER_END_POINT_ID                 2
    #define GP_NUMBER_OF_TRANSLATION_TABLE_ENTRIES  5
    #define GP_NUMBER_OF_PROXY_SINK_TABLE_ENTRIES       5
    #define CLD_GP_ATTR_ZGPS_COMMISSIONING_WINDOW
    #define CLD_GP_ATTR_ZGP_SHARED_SECURITY_KEY_TYPE
    #define CLD_GP_ATTR_ZGP_LINK_KEY
    *//* security level *//*
    #define GP_SECURITY_LEVEL E_GP_ENC_FULL_FC_FULL_MIC
    *//* Possible values are  E_GP_NO_KEY, E_GP_ZIGBEE_NWK_KEY, E_GP_ZGPD_GROUP_KEY,
        E_GP_NWK_KEY_DERIVED_ZGPD_GROUP_KEY, E_GP_OUT_OF_THE_BOX_ZGPD_KEY, E_GP_DERIVED_INDIVIDUAL_ZGPD_KEY*//*
    #define GP_KEYTPE              E_GP_ZGPD_GROUP_KEY
    #define GP_SHARED_KEY  { 0xC0 , 0xC1 , 0xC2 , 0xC3 , 0xC4 , 0xC5 , 0xC6 , 0xC7 , 0xC8 , 0xC9 , 0xCa , 0xCb , 0xCc , 0xCd , 0xCe , 0xCf}
#undef ZCL_NUMBER_OF_ENDPOINTS
#define ZCL_NUMBER_OF_ENDPOINTS                             2
#undef CLD_GROUPS_MAX_NUMBER_OF_GROUPS
#define CLD_GROUPS_MAX_NUMBER_OF_GROUPS                     4
#define GP_MAX_TRANS_ZB_CMD_PAYLOAD_LENGTH                   2
#endif*/
/*             Colour Control Cluster - Optional Attributes                 */
/* attributes to the time cluster.                                          */
 * Colour attributes, Optional in ZCL spec but Mandatory for ZLL
/* Colour information attribute set attribute ID's (5.2.2.2.1) */
#define CLD_COLOURCONTROL_ATTR_CURRENT_HUE
#define CLD_COLOURCONTROL_ATTR_CURRENT_SATURATION
#define CLD_COLOURCONTROL_ATTR_REMAINING_TIME
#define CLD_COLOURCONTROL_ATTR_COLOUR_MODE
#define CLD_COLOURCONTROL_ATTR_COLOUR_TEMPERATURE
//#define  SCENES_SERVER
/* Defined Primaries Information attribute attribute ID's set (5.2.2.2.2) */
#define CLD_COLOURCONTROL_ATTR_NUMBER_OF_PRIMARIES  3
/* Enable Primary (n) X, Y and Intensity attributes */
#define CLD_COLOURCONTROL_ATTR_PRIMARY_1
#define CLD_COLOURCONTROL_ATTR_PRIMARY_2
#define CLD_COLOURCONTROL_ATTR_PRIMARY_3
#define CLD_COLOURCONTROL_ATTR_PRIMARY_4
#define CLD_COLOURCONTROL_ATTR_PRIMARY_5
#define CLD_COLOURCONTROL_ATTR_PRIMARY_6
/* ZLL enhanced attributes */
#define CLD_COLOURCONTROL_ATTR_ENHANCED_CURRENT_HUE
#define CLD_COLOURCONTROL_ATTR_ENHANCED_COLOUR_MODE
#define CLD_COLOURCONTROL_ATTR_COLOUR_LOOP_ACTIVE
#define CLD_COLOURCONTROL_ATTR_COLOUR_LOOP_DIRECTION
#define CLD_COLOURCONTROL_ATTR_COLOUR_LOOP_TIME
#define CLD_COLOURCONTROL_ATTR_COLOUR_LOOP_START_ENHANCED_HUE
#define CLD_COLOURCONTROL_ATTR_COLOUR_LOOP_STORED_ENHANCED_HUE
#define CLD_COLOURCONTROL_ATTR_COLOUR_CAPABILITIES
#define CLD_COLOURCONTROL_ATTR_COLOUR_TEMPERATURE_PHY_MIN
#define CLD_COLOURCONTROL_ATTR_COLOUR_TEMPERATURE_PHY_MAX
#define CLD_COLOURCONTROL_ATTR_COLOUR_TEMPERATURE_MIRED
/* Max & Min Limits for colour temperature */
#define CLD_COLOURCONTROL_COLOUR_TEMPERATURE_PHY_MIN    0x0001
#define CLD_COLOURCONTROL_COLOUR_TEMPERATURE_PHY_MAX    0xfef8
#define CLD_COLOURCONTROL_RED_X     (0.68)
#define CLD_COLOURCONTROL_RED_Y     (0.31)
#define CLD_COLOURCONTROL_GREEN_X   (0.11)
#define CLD_COLOURCONTROL_GREEN_Y   (0.82)
#define CLD_COLOURCONTROL_BLUE_X    (0.13)
#define CLD_COLOURCONTROL_BLUE_Y    (0.04)
#define CLD_COLOURCONTROL_WHITE_X   (0.33)
#define CLD_COLOURCONTROL_WHITE_Y   (0.33)
#define CLD_COLOURCONTROL_PRIMARY_1_X           CLD_COLOURCONTROL_RED_X
#define CLD_COLOURCONTROL_PRIMARY_1_Y           CLD_COLOURCONTROL_RED_Y
#define CLD_COLOURCONTROL_PRIMARY_1_INTENSITY   (254 / 3)
#define CLD_COLOURCONTROL_PRIMARY_2_X           CLD_COLOURCONTROL_GREEN_X
#define CLD_COLOURCONTROL_PRIMARY_2_Y           CLD_COLOURCONTROL_GREEN_Y
#define CLD_COLOURCONTROL_PRIMARY_2_INTENSITY   (254 / 3)
#define CLD_COLOURCONTROL_PRIMARY_3_X           CLD_COLOURCONTROL_BLUE_X
#define CLD_COLOURCONTROL_PRIMARY_3_Y           CLD_COLOURCONTROL_BLUE_Y
#define CLD_COLOURCONTROL_PRIMARY_3_INTENSITY   (254 / 3)
#define CLD_COLOURCONTROL_PRIMARY_4_X           (0)
#define CLD_COLOURCONTROL_PRIMARY_4_Y           (0)
#define CLD_COLOURCONTROL_PRIMARY_4_INTENSITY   (0xff)
#define CLD_COLOURCONTROL_PRIMARY_5_X           (0)
#define CLD_COLOURCONTROL_PRIMARY_5_Y           (0)
#define CLD_COLOURCONTROL_PRIMARY_5_INTENSITY   (0xff)
#define CLD_COLOURCONTROL_PRIMARY_6_X           (0)
#define CLD_COLOURCONTROL_PRIMARY_6_Y           (0)
#define CLD_COLOURCONTROL_PRIMARY_6_INTENSITY   (0xff)
#define  CLD_COLOUR_CONTROL_SUPPORT_ZLL_ENHANCED_COMMANDS
#define  CLD_COLOUR_CONTROL_SUPPORT_ZLL_COLOUR_TEMPERATURE_COMMANDS
/* ZLL attribute in on off cluster */
//#define CLD_ONOFF_ATTR_GLOBAL_SCENE_CONTROL
//#define CLD_ONOFF_ATTR_ON_TIME
//#define CLD_ONOFF_ATTR_OFF_WAIT_TIME
#define ZLL_DISABLE_DEFAULT_RESPONSES FALSE
/* WARNING -- Need to setup bugger apdus and fragmentation to enable ASC */
//#define CLD_ASC_LOG
#define CLD_DOOR_LOCK
#define DOOR_LOCK_CLIENT
#define CLD_THERMOSTAT
#define THERMOSTAT_CLIENT
#define CLD_TEMPERATURE_MEASUREMENT
#define TEMPERATURE_MEASUREMENT_CLIENT
#define CLD_RELATIVE_HUMIDITY_MEASUREMENT
#define RELATIVE_HUMIDITY_MEASUREMENT_CLIENT
#define CLD_ILLUMINANCE_MEASUREMENT
#define ILLUMINANCE_MEASUREMENT_CLIENT
//#define CLD_APPLIANCE_STATISTICS
//#define APPLIANCE_STATISTICS_SERVER
//#define APPLIANCE_STATISTICS_CLIENT
#define CLD_SM_ATTR_INSTANTANEOUS_DEMAND
/***        Type Definitions                                              ***/
/***        Exported Functions                                            ***/
PUBLIC void* psGetDeviceTable(void);
/***        External Variables                                            ***/
/***        END OF FILE                                                   ***/
#endif /* ZCL_OPTIONS_H */
  • in app_zcl_event_handler
    1.  Add the on_off_light.h include.
      #include "on_off_light.h"
    2. In event app_zcl_event_handler.c  did the following Initialize the tsCLD_ZllDeviceTable
      tsZLO_ControlBridgeDevice sControlBridge;
      tsZLO_OnOffLightDevice sOnOFFLight1;
      tsZLO_OnOffLightDevice sOnOFFLight2;
      tsZLO_OnOffLightDevice sOnOFFLight3;
      tsZLO_OnOffLightDevice sOnOFFLight4;
      tsCLD_ZllDeviceTable sDeviceTable = {ZLO_NUMBER_DEVICES,
      {{0,
      ZLO_PROFILE_ID,
      CONTROL_BRIDGE_DEVICE_ID,
      CONTROLBRIDGE_ZLO_ENDPOINT,
      APPLICATION_DEVICE_VERSION,
      GROUPS_REQUIRED,
      0
      {0,
      ZLO_PROFILE_ID,
      ZLO_ON_OFF_LIGHT_DEVICE_ID,
      1,
      GROUPS_REQUIRED,
      0
      }, {0,
      ZLO_PROFILE_ID,
      2,
      GROUPS_REQUIRED,
      0
      }, {0,
      ZLO_PROFILE_ID,
      3,
      GROUPS_REQUIRED,
      0
      }, {0,
      ZLO_PROFILE_ID,
      4,
      GROUPS_REQUIRED,
      0
      APP_tsAplMacInstallCodeTable sMacInstallCodeTable;
      tsZllEndpointInfoTable sEndpointTable;
      tsZllGroupInfoTable sGroupTable;
      #endif
    3.  Initialize the Endpoints and register them in APP_ZCL_vInitialise()
      /* Register Commission EndPoint */
      eZCL_Status = eApp_ZLO_RegisterEndpoint(&APP_ZCL_cbEndpointCallback);
      if (eZCL_Status != E_ZCL_SUCCESS) {
      vLog_Printf (TRACE_ZB_CONTROLBRIDGE_TASK, LOG_CRIT, "eApp_ZLO_RegisterEndpoint %x\n", eZCL_Status);
      vSL_LogFlush();
      /* Register Light 1 EndPoint */
      eZCL_Status = eZLO_RegisterOnOffLightEndPoint(1,
      &APP_ZCL_cbEndpointCallback,
      &sOnOFFLight1);
      DBG_vPrintf(TRUE, "\n Registering ce App_ZLO_RegisterEndpoint 1 light %xd \n", eZCL_Status);
      /* Register Light 2 EndPoint */
      eZCL_Status = eZLO_RegisterOnOffLightEndPoint(2,
      &sOnOFFLight2);
      DBG_vPrintf(TRUE, "\n Registering ce App_ZLO_RegisterEndpoint 2 light %xd \n", eZCL_Status);
      /* Register Light 3 EndPoint */
      eZCL_Status = eZLO_RegisterOnOffLightEndPoint(3,
      &sOnOFFLight3);
      DBG_vPrintf(TRUE, "\n Registering ce App_ZLO_RegisterEndpoint 3 light %xd \n", eZCL_Status);
      eZCL_Status = eZLO_RegisterOnOffLightEndPoint(4,
      &sOnOFFLight4);
      DBG_vPrintf(TRUE, "\n Registering ce App_ZLO_RegisterEndpoint 4 light %xd \n", eZCL_Status);
      sDeviceTable.asDeviceRecords[0].u64IEEEAddr = ZPS_u64NwkNibGetExtAddr(ZPS_pvAplZdoGetNwkHandle());
      sDeviceTable.asDeviceRecords[1].u64IEEEAddr = ZPS_u64NwkNibGetExtAddr(ZPS_pvAplZdoGetNwkHandle());
      sDeviceTable.asDeviceRecords[2].u64IEEEAddr = ZPS_u64NwkNibGetExtAddr(ZPS_pvAplZdoGetNwkHandle());
      sDeviceTable.asDeviceRecords[3].u64IEEEAddr = ZPS_u64NwkNibGetExtAddr(ZPS_pvAplZdoGetNwkHandle());
      vLog_Printf (TRACE_ZB_CONTROLBRIDGE_TASK, LOG_DEBUG, "\ntsCLD_Groups %d", sizeof(tsCLD_Groups));
      vLog_Printf (TRACE_ZB_CONTROLBRIDGE_TASK, LOG_DEBUG, "\ntsCLD_GroupTableEntry %d", sizeof(tsCLD_GroupTableEntry));
      vAPP_ZCL_DeviceSpecific_Init();
I am not able to understand why the 255 EP , and group commands dont work here?
Is there any code part in the JN-AN-1247 that is responsibble for this as normally the AN-JN-1247 has two endpoints  (control Bridge and the other GP)?
Can anyone point me to the entry point of / first  function that gets called as soon as the device gets any data related to zigbee commands in ZCL as well
14 回复数
11,259 次查看
EduardoZamora
Hello @dmsherazi
Just to confirm, are you trying to perform a broadcast from one end point (Control Bridge) to several On/Off compatible devices (Lights)?
Could you please confirm that you have read [JN-UG-3131-ZigBee3-Devices] Section 1.4 Device Initialisation and Chapter 3 Lighting and Occupancy Device Types, Section 3.1 On/Off Light?
Also, could you please share your Light End Point properties?
Eduardo.
11,236 次查看
dmsherazi
Thanks for your response @EduardoZamora
No. Sending to short/Nw address but selecting 255 as EP wont send command to the Light at EP 3 & 4. Ep 1 and 2 will recieve the command. When sending command to EP 3 and 4 by using destination EP as 3 or 4 will work.
Also when sending a command to group address. 3 & 4 wont get the command!
>>  Properties of ENDPOINTS
I am attaching the project files for you to check them. I am using the Full Fuction device Without GP  ControlBridge_Full.zpscfg
11,223 次查看
EduardoZamora
I really appreciate the details.
My apologies, I am having a hard time understanding the scenario and trying to replicate this behavior. Could you please confirm if the following picture represents what you are testing?
Eduardo.
11,202 次查看
dmsherazi
The situation is like this . I have two devices . One loaded with ControlBridge App Note without modifications. This acts as cordinator as well as control bridge.
The second One has been modified in the sense that 4 ON/OFF Lights are added to it. One Light is added on Ep1 which has the controlbridge as well. and other lights are on Ep 2 , 3 and 4. This device is set to work as Router Control Bridge.
Situation is like this. When I send any command to the Second CB from the first where destination EP is 255 , ideally All Four Lights should get the command and execute but only EP1 and Ep2 gets it. It should be noted that when I send the same comamnd to each endpoint individually the commands are recived.
Further more its worth mentioning that sending the command to broadcast endpoit on any other 3 or 4 gun light will work as expected
11,183 次查看
EduardoZamora
Are you using the ZGWUI tool to communicate with the Control Bridge + Lights device? If so, could you please share the log?
Also, would it be possible for you to catch this event with a sniffer? This information would be very helpful.
Eduardo.
11,160 次查看
dmsherazi
 HI @EduardoZamora :
For development purposes I am using the ZGWUI for both the controlbridge and the router with lights.
I have  recorded a screencast showing the scenario.
The issue in short is that all endpoints (1,2,3&4) responds when I send command to a specified endpoint (where destination endpoint is 1,2,3 or 4). but when the destination endpoint is 255 (0xFF) in the command then only endpoint 1 and 2 will get that and not 3 & 4.
https://drive.google.com/file/d/1F7SniPYPbJbznODkKo0EAwKjxO70wP0R/preview
11,137 次查看
EduardoZamora
Could you please try adding Basic cluster to the Light End Points? This cluster is mandatory for all ZigBee devices [JN-UG-3132 ZigBee3 Cluster Library, Chapter 8 Basic Cluster].
You can find mandatory clusters for each End Point in SDK folder > docs > wireless > Zigbee > JN-UG-3131 ZigBee3 Devices, Chapter 3 Lighting and Occupancy Device Types.
Eduardo.
11,088 次查看
dmsherazi
I already added it , and its the same - No improvemnets. Can you explain how the broadcast endpoint is handled at the stack level?
10,972 次查看
EduardoZamora
Please, take a look at JN-UG-3130 Zigbee3 Stack, Section 3.4 Application level concepts. Also, please consider reading the following information.
  • JN-UG-3130 Zigbee3 Stack, Section 6.2.2 Finding compatible endpoints.
  • JN-UG-3131 Zigbee3 Devices, Section 1.3 Shared Devices Structure, Figure 2. Please, take a look at the entire Chapter 1 of this User Guide.
  • JN-UG-3132 Zigbee3 Cluster Library, Section 2.3 Accessing Attributes.
I apologize for insisting, but would it be possible for you to capture this event with a sniffer? This information would be very helpful.
Eduardo.
10,899 次查看
dmsherazi
I tried to use the KPAA utility with wireshark here are the sniffed packets. When I send a toggle command to EP255 only 1 and 2 gets it and 3 doesnt
I have gon through these chapters that you mentioned and couldnt still solve the issue.
I found that eZCL_SearchForClusterEntry() gives E_ZCL_ERR_CLUSTER_NOT_FOUND. I found that when I was trying to send an on/off command from this device.
Although as mentioned above the clusters are added in .zpcfg file. and the endpoint is registered uising the eZLO_RegisterOnOffLightEndPoint functionon ep 1,2,3,4 so why would the serach for cluster on the endpoints fail? is there any other step to register /add the cluster on the endpoint?
@EduardoZamora  I aslo came accorss PRIVATE bool_t g_bIgnoreBroadcast [ 1 ] = {TRUE,}; in the zps_gen.c but couldnt find any resource explaining it. Can you please explain that variable as well
10,831 次查看
EduardoZamora
Hi @dmsherazi
I truly apologize for the delay on my response.
I am still checking this issue. Please give me some time and I will reply to you as soon as possible.
Eduardo.
10,847 次查看
dmsherazi
@EduardoZamora Kindly look at this please!
10,612 次查看
EduardoZamora
Hello @dmsherazi,
This case will be followed in the internal ticket.
Eduardo.
11,285 次查看
dmsherazi
@EduardoZamora
@mario_castaneda
Please Help!
