Script for CLEV6630B to work NTAG5 as an I2C-Master
1,046 次查看
ME1234
I am working with the CLEV6630B and the NXP-NFC-Cockpit (v.7.1.0). I've a NTAG5 connected via I2C to a sensor. Now I want to read the sensor data with a script. Are there any example scripts available with I2C_READ and I2C_WRITE commands? I only could find things like  WriteEEPROM .
kind regards
标记 (1)
1 回复
1,017 次查看
KaiLi
Hello @ME1234
Thanks for contacting us and choosing the NXP products.
Yes, there is an example which is based on LPC host and running on MCUXpress IDE can be reference for you.
I've downloaded for you, please check the attachment.
Please feel free to contact us if any questions.
To update this case, you may reply by email.
To provide confidential information or attachments, you may add that online.
Please login to our NXP technical support portal:
https://support.nxp.com/s/case/5002p00002tc89ZAAQ
The portal allows access to the full details of the case, including the previous communication.
Thank you for your interest in NXP Semiconductor products and for the opportunity to serve you.
Kelly
Technical Support
NXP Semiconductor
