RW612 roaming setting
johnny_h
Dear community, I have a few questions about the roaming setting. I’m running the wifi-wpa-supplicant example and enable roaming (wlan_set_roaming(1, 70))when connected to a network. I’ve noticed that it triggers a low rssi event when the rssi drops below 70 and initiates a regular scan instead of background scan. However, if I disable wpa_supplicant, it performs a background scan instead of a regular scan. Why is there a difference?
WPA_supplicant supports background scan(CONFIG_BGSCAN), but it (bgscan.c) appears to be removed from the example program. Is there a reason for this?
In my current setup, roaming will only be initiated when the RSSI drops below a specific threshold. How can I set up a scheduled scan to initiate roaming when it discovers a stronger access point?
Many thanks and regards
weidong_sun
Dear @johnny_h ,
See the following explanations for your questions from our internal team, please!
Dear community, I have a few questions about the roaming setting. I’m running the wifi-wpa-supplicant example and enable roaming (wlan_set_roaming(1, 70))when connected to a network. I’ve noticed that it triggers a low rssi event when the rssi drops below 70 and initiates a regular scan instead of background scan. However, if I disable wpa_supplicant, it performs a background scan instead of a regular scan. Why is there a difference?WPA_supplicant supports background scan(CONFIG_BGSCAN), but it (bgscan.c) appears to be removed from the example program. Is there a reason for this?
[NXP]
  • This is not an issue, it is expected behavior in 24.12.00 SDK version.
  • This is an improvement in 24.12.00 SDK.
  • Before 24.12.00, the behavior was, during roam bgscan happened and bgscan scans all 36 channels and during that ~3 sec of time period no data exchange happens.
  • Now, to improve this behavior NXP implemented and instead of bgscan executing normal scan during roaming. Normal roaming do split scan so, we will not get continuous data drop.
[NXP] Are you expecting to roam before low rssi event come. Normally low rssi event come when we cross the rssi threshold.
Thanks!
weidong
weidong_sun
Dear @johnny_h ,
[NXP]
Thanks!
weidong
johnny_h
The SDK version is 24_12_00
%3CLINGO-SUB%20id%3D%22lingo-sub-2063238%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERW612%20roaming%20setting%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2063238%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3EDear%20community%2C%20I%20have%20a%20few%20questions%20about%20the%20roaming%20setting.%20I%E2%80%99m%20running%20the%20wifi-wpa-supplicant%20example%20and%20enable%20roaming%20(wlan_set_roaming(1%2C%2070))when%20connected%20to%20a%20network.%20I%E2%80%99ve%20noticed%20that%20it%20triggers%20a%20low%20rssi%20event%20when%20the%20rssi%20drops%20below%2070%20and%20initiates%20a%20regular%20scan%20instead%20of%20background%20scan.%20However%2C%20if%20I%20disable%20wpa_supplicant%2C%20it%20performs%20a%20background%20scan%20instead%20of%20a%20regular%20scan.%20Why%20is%20there%20a%20difference%3F%3C%2FP%3E%3CP%20class%3D%22%22%3EWPA_supplicant%20supports%20background%20scan(CONFIG_BGSCAN)%2C%20but%20it%20(bgscan.c)%20appears%20to%20be%20removed%20from%20the%20example%20program.%20Is%20there%20a%20reason%20for%20this%3F%3C%2FP%3E%3CP%20class%3D%22%22%3EIn%20my%20current%20setup%2C%20roaming%20will%20only%20be%20initiated%20when%20the%20RSSI%20drops%20below%20a%20specific%20threshold.%20How%20can%20I%20set%20up%20a%20scheduled%20scan%20to%20initiate%20roaming%20when%20it%20discovers%20a%20stronger%20access%20point%3F%3C%2FP%3E%3CP%20class%3D%22%22%3EMany%20thanks%20and%20regards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2068672%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20RW612%20roaming%20setting%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2068672%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248167%22%20target%3D%22_blank%22%3E%40johnny_h%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ESee%20the%20following%20explanations%20for%20your%20questions%20from%20our%20internal%20team%2C%20please!%3C%2FP%3E%0A%3CP%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%0A%3CP%3EDear%20community%2C%20I%20have%20a%20few%20questions%20about%20the%20roaming%20setting.%20I%E2%80%99m%20running%20the%20wifi-wpa-supplicant%20example%20and%20enable%20roaming%20(wlan_set_roaming(1%2C%2070))when%20connected%20to%20a%20network.%20I%E2%80%99ve%20noticed%20that%20it%20triggers%20a%20low%20rssi%20event%20when%20the%20rssi%20drops%20below%2070%20and%20initiates%20a%20regular%20scan%20instead%20of%20background%20scan.%20However%2C%20if%20I%20disable%20wpa_supplicant%2C%20it%20performs%20a%20background%20scan%20instead%20of%20a%20regular%20scan.%20Why%20is%20there%20a%20difference%3FWPA_supplicant%20supports%20background%20scan(CONFIG_BGSCAN)%2C%20but%20it%20(bgscan.c)%20appears%20to%20be%20removed%20from%20the%20example%20program.%20Is%20there%20a%20reason%20for%20this%3F%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%5BNXP%5D%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EThis%20is%20not%20an%20issue%2C%20it%20is%20expected%20behavior%20in%2024.12.00%20SDK%20version.%3C%2FLI%3E%0A%3CLI%3EThis%20is%20an%20improvement%20in%2024.12.00%20SDK.%3C%2FLI%3E%0A%3CLI%3EBefore%2024.12.00%2C%20the%20behavior%20was%2C%20during%20roam%20bgscan%20happened%20and%20bgscan%20scans%20all%2036%20channels%20and%20during%20that%20~3%20sec%20of%20time%20period%20no%20data%20exchange%20happens.%3C%2FLI%3E%0A%3CLI%3ENow%2C%20to%20improve%20this%20behavior%20NXP%20implemented%20and%20instead%20of%20bgscan%20executing%20normal%20scan%20during%20roaming.%20Normal%20roaming%20do%20split%20scan%20so%2C%20we%20will%20not%20get%20continuous%20data%20drop.%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CP%3EIn%20my%20current%20setup%2C%20roaming%20will%20only%20be%20initiated%20when%20the%20RSSI%20drops%20below%20a%20specific%20threshold.%20How%20can%20I%20set%20up%20a%20scheduled%20scan%20to%20initiate%20roaming%20when%20it%20discovers%20a%20stronger%20access%20point%3F%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%5BNXP%5D%3C%2FSTRONG%3E%26nbsp%3BAre%20you%20expecting%20to%20roam%20before%20low%20rssi%20event%20come.%20Normally%20low%20rssi%20event%20come%20when%20we%20cross%20the%20rssi%20threshold.%3C%2FP%3E%0A%3CP%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThanks!%3C%2FP%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3Eweidong%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2063239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20RW612%20roaming%20setting%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2063239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20SDK%20version%20is%2024_12_00%3C%2FP%3E%3C%2FLINGO-BODY%3E
