QN9090-DK006 I am trying to receive numeric data (eg 1 to 10) from MCU to PC via BLE using QN9090-DK006 Bluetooth.
Since I am a beginner in creating MCU Code, I do not know the reference SDK and change points.
Is there a point (ID setting) etc. in SW creation on the PC side?
There are many unclear points, but I would like to ask for your help.
Solved! Go to Solution.
Hi, @TM33
Could you tell me which SDK(SDK version) and which project are you using?
About download SDK, you can go to :https://mcuxpresso.nxp.com/en/welcome and select your development board, then start to build SDK according to your requirement.
Also for new beginner, it is better to read our :Getting Started with MCUXpresso SDK for
QN9090.pdf for reference.
Hope above info is helpful for you.
Christine.
Hi, @TM33
Christine.
