QN908x Capacitive touch sense
2,058件の閲覧回数
yashodip_c
I am planning to use "QN908x" for capacitive touch functionality. Kindly clarify below queries,
1. Can design separate board for touch panel this board can be interface with main board (with QN908x )??
Is it necessary to have touch panel on the main board only?
2. Can I achieve swipe functionality using multiple touch switches on "QN908x"?
Yash
3 返答(返信)
1,967件の閲覧回数
yashodip_c
Could you please share schematic of "Touch Sense Board".
1,967件の閲覧回数
estephania_mart
The files that we have in the web page are the only ones we have available to share.
Sorry for the inconveniences this might cause you .
Estephania
1,967件の閲覧回数
estephania_mart
Hello ,
By any chance have you checked the AN12190  I believe that this guide could be a nice start in your desing development and might help you clarify most of the questions you have.
You can check the chapter 5 with some of the HW Setup used in the making of the file , you can check as well the chapter 4 the supported patterns to be supports pattern, keypad, analog rotary, and analog slider.
Estephania
