Pegoda Smart Card Reader Based on PN7642
2,411 次查看
Eric12285
Hi Sir,
Can we have a firmware source code of Pegoda Smart Card Reader?
We'd like to design a reader based Pegoda Smart Card Reader.
Also, is the SDK including driver, firmware update utility, programing interface guidance and sample code ready? The operating systems are WIndows and Linux.
Eric Fu
2,260 次查看
KaiLi
About the CCID driver for Linux that can be supported by PN7642, can you share the file and link?
Ans: The CCID driver under Linux is standard and does not need to be provided separately. You can install it yourself.
6 回复数
2,339 次查看
Eric12285
Sorry, correct my questions.
PN7642 is an NFC forum certified solution. May I check if the USB interface is included in the certified configuration? And does the shared firmware on the website cover this?
Eric Fu
2,261 次查看
KaiLi
2,268 次查看
KaiLi
Hello @Eric12285
Ans: Pegoda 3 is NFC Forum certified, Pegoda3 is a complete standalone product, USB is included in it.
2,257 次查看
Eric12285
Hi Kelly,
Thank you. How about the shared SDK and firmware for PN7642 itself(not talking about the Pegoda)? We want to use the shared SDK and firmware and want to make sure if the USB is included. I guess yes after I check there is a CCID related example code in the share SDK. Please help confirm that.
Eric Fu
2,385 次查看
KaiLi
Hello @Eric12285
Firmware source code of Pegoda Smart Card Reader should be not available for the user. But PN7642 SDK is open source, you can download on the product page.
Single-Chip Solution with High-Performance NFC Reader, Customizable MCU and Security Toolbox | NXP S...
2,378 次查看
Eric12285
Thanks, Kelly
About the CCID interface protocol, does the share firmware cover this for both Windows and Linux?
Eric Fu
