Panasonic Wi-Fi® & Bluetooth® Evaluation Kit: PAN9026 support for i.MX RT1020?
jrnTransAct
Does the PAN9026 evaluation kit support the i.MX RT1020?
The page calls out a few different RT parts, but not the RT1020 specifically.
Jim Norton
Sr. Firmware Engineer - TransAct Technologies, Inc.
kerryzhou
Hi JimNortonTACT,
In fact, in the wifi project readme, it contains the information:
Hardware requirements
- 2x Micro USB cable
- evkmimxrt1020 board
- Personal Computer
- Murata 1DX or 1LV M.2 module
- Murata uSD M.2 Adapter
- 1 plug to receptable header cable
Wish it helps you!
If you still have questions about it, please kindly let me know.
Kerry
jrnTransAct
@kerryzhou thank you again. Do you have an HTTP link to "SDK_2.9.1_EVK-MIMXRT1020\boards\evkmimxrt1020\wifi_cypress_examples"?
Regards.
Jim Norton
kerryzhou
Hi JimNortonTACT,
  Now, our NXP RT SDK which use the PAN9026 wifi module are mainly: MIMXRT1050, MIMXRT1060, MIMXRT1064,mimxrt685,MIMXRT595.
  To MIMXRT1020, now just contains cypress wifi module:
no SDK code for PAN9026 now.
Wish it helps you!
Kerry
jrnTransAct
Hello @kerryzhou ,
Thank you for the answer. Would you mind telling what Cypress module is supported by the RT1020 SDK?
Or perhaps a direct link to "SDK_2.9.1_EVK-MIMXRT1020\boards\evkmimxrt1020\wifi_cypress_examples"?
Thank you.
Jim Norton
kerryzhou
Hi JimNortonTACT,
- Personal Computer
Wish it helps you!
Kerry
jrnTransAct
@kerryzhou thank you.
Would you please provide a link to that project?
Also, do you have links to the required Murata WiFi parts?
Thank you.
Jim Norton
kerryzhou
Hi JimNortonTACT,
 Code can be downloaded from the SDK link:
https://mcuxpresso.nxp.com/
 In the middleware, select all, and generate the code an download it.
Wish it helps you!
Kerry
