Panasonic Wi-Fi® & Bluetooth® Evaluation Kit: PAN9026 support for i.MX RT1020?
3,139件の閲覧回数
jrnTransAct
Does the PAN9026 evaluation kit support the i.MX RT1020?
The page calls out a few different RT parts, but not the RT1020 specifically.
Jim Norton
Sr. Firmware Engineer - TransAct Technologies, Inc.
3,071件の閲覧回数
kerryzhou
Hi JimNortonTACT,
In fact, in the wifi project readme, it contains the information:
Hardware requirements
- 2x Micro USB cable
- evkmimxrt1020 board
- Personal Computer
- Murata 1DX or 1LV M.2 module
- Murata uSD M.2 Adapter
- 1 plug to receptable header cable
Wish it helps you!
If you still have questions about it, please kindly let me know.
Kerry
6 返答(返信)
3,061件の閲覧回数
jrnTransAct
@kerryzhou thank you again. Do you have an HTTP link to "SDK_2.9.1_EVK-MIMXRT1020\boards\evkmimxrt1020\wifi_cypress_examples"?
Regards.
Jim Norton
3,116件の閲覧回数
kerryzhou
Hi JimNortonTACT,
  Now, our NXP RT SDK which use the PAN9026 wifi module are mainly: MIMXRT1050, MIMXRT1060, MIMXRT1064,mimxrt685,MIMXRT595.
  To MIMXRT1020, now just contains cypress wifi module:
no SDK code for PAN9026 now.
Wish it helps you!
Kerry
3,091件の閲覧回数
jrnTransAct
Hello @kerryzhou ,
Thank you for the answer. Would you mind telling what Cypress module is supported by the RT1020 SDK?
Or perhaps a direct link to "SDK_2.9.1_EVK-MIMXRT1020\boards\evkmimxrt1020\wifi_cypress_examples"?
Thank you.
Jim Norton
3,072件の閲覧回数
kerryzhou
Hi JimNortonTACT,
- Personal Computer
Wish it helps you!
Kerry
3,057件の閲覧回数
jrnTransAct
@kerryzhou thank you.
Would you please provide a link to that project?
Also, do you have links to the required Murata WiFi parts?
Thank you.
Jim Norton
3,022件の閲覧回数
kerryzhou
Hi JimNortonTACT,
 Code can be downloaded from the SDK link:
https://mcuxpresso.nxp.com/
 In the middleware, select all, and generate the code an download it.
Wish it helps you!
Kerry
An error has occurred when reading existing sub-variable "Language_PG_Configuration"; see cause exception! The type of the containing value was: extended_hash+string (lithium.coreapi.webui.template.models.NamedValueByNameTemplateModel wrapped into f.e.b.StringModel) ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign redirect_lingo_page_url = web... [in template "language_macro_header.ftl" at line 173, column 1] - Reached through: #include "language_macro_header.ftl" [in template "Language_translator_Dashboard" at line 3, column 1] ----
