PNEV7462C Antenna Adaptation Measurement
Pel
Hello NXP community,
I'm currently trying to modify the PNEV7462C to separate the antenna from the board with a cable (around 2 feet long).
To adapt the new system I'm following the NXP guide : 'PN7120 Antenna Design and Matching Guide' (https://www.nxp.com/docs/en/application-note/AN11564.pdf) I want to measure the impedance of my new matching circuit to adjust it. But with the EMC filter split by the probing vias, I don't know how to measure the new adaptation. To compare it with the old system I'd like to probe at the same place as the figure 9 in the 'PN7462 family Quick Guide' (https://www.nxp.com/docs/en/user-guide/UM10883.pdf) (Which is I think between the EMC filter and the uC).
Where and how can I measure the impedance of the antenna with my new matching circuit ?
Best regards.
fangfang
Hello @Pel .
Thanks for your information . I provided the information for the question via you submitted case. Please kindly check it.
Have a nice day.
fangfang
Hello @Pel .
Have a nice day.
