PN7642 C101 Debug mode entering error
ソリューションへジャンプ
2,669件の閲覧回数
artem_pn
Hello!
I`m using PN7642EV/C101. On my custom board (I haven`t found DevKit for this version of IC) I can not enter debug mode. I`m using MCU Link to load and debug FW. During the connection sequence I have next log:
Reconnected to existing LinkServer process.
============= SCRIPT: PN7642_connect.scp =============
PN7642 Connect Script
Connecting to Probe Index = 1
This probe = 1
This TAP = 0
This core = 0
DpID = 6BA02477
Breakpoints before reset
Number of FPBs: 8
FPB:0 COMP: 0x00208131 (0x00208130)
FPB:1 COMP: 0x20003003 (0x20003002)
FPB:2 COMP: 0x00000000 (not in use)
FPB:3 COMP: 0x00000000 (not in use)
FPB:4 COMP: 0x00000000 (not in use)
FPB:5 COMP: 0x00000000 (not in use)
FPB:6 COMP: 0x00000000 (not in use)
FPB:7 COMP: 0x00000000 (not in use)
Sending CMSYSRESETREQ
Error: Wire Ack Fault - target connected?
DpID = 6BA02477
Registers after reset
R0 : 00000000
R1 : 00208130
R2 : 00208130
R3 : 00208130
R4 : 00208130
R5 : 00208130
R6 : 00208130
R7 : 00208130
R8 : 00208130
R9 : 00208130
R10 : 00208130
R11 : 00208130
R12 : 00208130
SP : 20008000
LR : FEFFFFFF
PC : 00208130
PSR : 01000000
MSP : 20008000
PSP : 00000000
CFBP: 00000000
============= END SCRIPT =============================
Probe Firmware: MCU-LINK r0FF CMSIS-DAP V0.078 (NXP Semiconductors)
Serial Number: KJKL4QM3ADBKP
VID:PID: 1FC9:0143
USB Path: \\?\hid#vid_1fc9&pid_0143&mi_00#7&1db5e7dc&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
Using memory from core 0 after searching for a good core
debug interface type = CoreSight DP (DAP DP ID 6BA02477) over SWD TAP 0
processor type = Cortex-M33 (CPU ID 00000D21) on DAP AP 0
number of h/w breakpoints = 8
number of flash patches = 0
number of h/w watchpoints = 4
Probe(0): Connected&Reset. DpID: 6BA02477. CpuID: 00000D21. Info: <None>
Debug protocol: SWD. RTCK: Disabled. Vector catch: Disabled.
Content of CoreSight Debug ROM(s):
RBASE E00FE000: CID B105100D PID 0000080000 ROM (type 0x1)
ROM 1 E00FF000: CID B105100D PID 04000BB4C9 ROM (type 0x1)
ROM 2 E000E000: CID B105900D PID 04000BBD21 CSt ARM ARMv8-M type 0x0 Misc - Undefined
ROM 2 E0001000: CID B105900D PID 04000BBD21 CSt ARM DWTv2 type 0x0 Misc - Undefined
ROM 2 E0002000: CID B105900D PID 04000BBD21 CSt ARM FPBv2 type 0x0 Misc - Undefined
ROM 2 E0000000: CID B105900D PID 04000BBD21 CSt ARM ITMv2 type 0x43 Trace Source - Bus
ROM 2 E0041000: CID B105900D PID 04002BBD21 CSt ARM ETMv4.0 type 0x13 Trace Source - Core
ROM 2 E0042000: CID B105900D PID 04000BBD21 CSt ARM CTIv2 type 0x14 Debug Control - Trigger, e.g. ECT
ROM 1 E0045000: CID B105900D PID 04004BB907 CSt ETB type 0x21 Trace Sink - ETB
ROM 1 E0044000: CID B105900D PID 04002BB909 CSt type 0x22 Trace Link - Filter
ROM 1 E0046000: CID B105900D PID 04005BB906 CSt type 0x14 Debug Control - Trigger, e.g. ECT
NXP: PN7642
DAP stride is 1024 bytes (256 words)
Inspected v.2 On-chip Flash Memory PN7642.cfx
Image 'PN7642 Flash Apr 5 2024 18:22:54'
( 65) Chip Setup Complete
Connected: was_reset=false. was_stopped=true
Awaiting telnet connection to port 3330 ...
GDB nonstop mode enabled
FreeRTOS stack backtrace is disabled
Opening flash driver PN7642.cfx
VECTRESET requested, but not supported on ARMv8-M CPUs. Using SOFTRESET instead.
Using SOFT reset to run the flash driver
Flash device supported (180KB = 360*512 at 0x208000)
Writing 150608 bytes to address 0x00208000 in Flash
Sectors written: 0, unchanged: 295, total: 295
Erased/Wrote sector 0-294 with 150608 bytes in 155msec
Closing flash driver PN7642.cfx
Flash Write Done
Opening flash driver PN7642.cfx (already resident)
Writing 1540 bytes to address 0x00233000 in Flash
Sectors written: 0, unchanged: 4, total: 4
Erased/Wrote sector 344-347 with 1540 bytes in 26msec
Flash Write Done
Flash Program Summary: 152146 bytes in 0.18 seconds (816.37 KB/sec)
============= SCRIPT: PN7642_reset.scp =============
PN7642 Reset Script
Number of FPBs: 8
DpID = 6BA02477
Registers after CMSYSRESETREQ
R0 : 00000000
R1 : 00208130
R2 : 00208130
R3 : 00208130
R4 : 00208130
R5 : 00208130
R6 : 00208130
R7 : 00208130
R8 : 00208130
R9 : 00208130
R10 : 00208130
R11 : 00208130
R12 : 00208130
SP : 20008000
LR : FEFFFFFF
PC : 00208130
PSR : 01000000
MSP : 20008000
PSP : 00000000
CFBP: 00000000
DpID = 6BA02477
After PN76_Sys_Hal_SoftReset(1)
Error: Could not read registers (0x05)
state - running or following reset request - re-read of state failed - rc Nn(05). Wire ACK Fault in DAP access
following reset read of core registers failed - Ep(08). Cannot access core regs when target running.
Target error from Commit Flash write: Ep(08). Cannot access core regs when target running.
GDB stub (C:\nxp\LinkServer_1.5.30\binaries\crt_emu_cm_redlink) terminating - GDB protocol problem: Pipe has been closed by GDB.
What can be the reason of such behavior?
Thanks in advance!
Artem
タグ(1)
2,617件の閲覧回数
danielchen
Hi Artem:
The error message is : Target marked as not debuggable.    I would suggest you refer to below link,  this issue was discussed.
02: Failed on connect: Ep(01). Target marked as not debuggable - NXP Community
you can try other debug probe, like MCU link pro.
4 返答(返信)
2,638件の閲覧回数
artem_pn
Hi Daniel, thank you for response. I updated version of my MCU Link (not pro), anyway it is useful but unfortunately didn`t help. Another bad symptom is that when I configure debugger in such a way
and trying to to run debug sequence, I got this message:
Is there something you know can be the possible reason?
Thanks in advance!
Artem
2,618件の閲覧回数
danielchen
Hi Artem:
2,572件の閲覧回数
artem_pn
Thank you, Daniel!
Artem
タグ(1)
2,650件の閲覧回数
danielchen
Are you using MCU Link pro?
I would suggest you update the firmware for the MCU LINK pro and try it again.
Getting Started with the MCU-Link Pro | NXP Semiconductors
Regads
%3CLINGO-SUB%20id%3D%22lingo-sub-1969238%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPN7642%20C101%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AB%E5%85%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1969238%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%81%3C%2FP%3E%3CP%3EPN7642EV%2FC101%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89(%E3%81%93%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AEIC%E7%94%A8%E3%81%AEDevKit%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93)%E3%81%A7%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%85%A5%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82MCU%20Link%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6FW%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A8%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%8E%A5%E7%B6%9A%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E4%B8%AD%E3%81%AB%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%AD%E3%82%B0%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%97%A2%E5%AD%98%E3%81%AE%20LinkServer%20%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AB%E5%86%8D%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%3APN7642_connect.scp%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3EPN7642%20%E6%8E%A5%E7%B6%9A%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%E3%81%B8%E3%81%AE%E6%8E%A5%E7%B6%9A%20%3D%201%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3D%201%3CBR%20%2F%3E%E3%81%93%E3%81%AE%20TAP%20%3D%200%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E3%82%B3%E3%82%A2%20%3D%200%3CBR%20%2F%3EDPID%3D6BA02477%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%89%8D%E3%81%AE%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%3CBR%20%2F%3EFPB%E6%95%B0%3A8%3CBR%20%2F%3EFPB%3A0%20%E3%82%B3%E3%83%B3%E3%83%97%3A0x00208131%20(0x00208130)%3CBR%20%2F%3EFPB%3A1%E3%82%B3%E3%83%B3%E3%83%97%3A0x20003003(0x20003002)%3CBR%20%2F%3EFPB%3A2%20COMP%3A0x00000000(%E6%9C%AA%E4%BD%BF%E7%94%A8)%3CBR%20%2F%3EFPB%3A3%20COMP%3A0x00000000(%E6%9C%AA%E4%BD%BF%E7%94%A8)%3CBR%20%2F%3EFPB%3A4%20COMP%3A0x00000000(%E6%9C%AA%E4%BD%BF%E7%94%A8)%3CBR%20%2F%3EFPB%3A5%20COMP%3A0x00000000%20(%E6%9C%AA%E4%BD%BF%E7%94%A8)%3CBR%20%2F%3EFPB%3A6%20COMP%3A0x00000000(%E6%9C%AA%E4%BD%BF%E7%94%A8)%3CBR%20%2F%3EFPB%3A7%20COMP%3A0x00000000%20(%E6%9C%AA%E4%BD%BF%E7%94%A8)%3CBR%20%2F%3ECMSYSRESETREQ%20%E3%81%AE%E9%80%81%E4%BF%A1%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20Wire%20Ack%20Fault%20-%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%8C%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3EDPID%3D6BA02477%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%BE%8C%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3CBR%20%2F%3ER0%20%3A%2000000000%3CBR%20%2F%3ER1%20%3A%2000208130%3CBR%20%2F%3ER2%20%3A%2000208130%3CBR%20%2F%3ER3%20%3A%2000208130%3CBR%20%2F%3ER4%20%3A%2000208130%3CBR%20%2F%3ER5%20%3A%2000208130%3CBR%20%2F%3ER6%3A00208130%3CBR%20%2F%3ER7%20%3A%2000208130%3CBR%20%2F%3ER8%3A00208130%3CBR%20%2F%3ER9%20%3A%2000208130%3CBR%20%2F%3ER10%20%3A%2000208130%3CBR%20%2F%3ER11%20%3A%2000208130%3CBR%20%2F%3ER12%20%3A%2000208130%3CBR%20%2F%3ESP%20%3A%2020008000%3CBR%20%2F%3ELR%20%3A%20FEFFFFFF%3CBR%20%2F%3E%E3%83%91%E3%82%BD%E3%82%B3%E3%83%B3%20%3A%2000208130%3CBR%20%2F%3EPSR%E7%95%AA%E5%8F%B7%20%3A%2001000000%3CBR%20%2F%3EMSP%E7%95%AA%E5%8F%B7%20%3A%2020008000%3CBR%20%2F%3EPSP%E7%95%AA%E5%8F%B7%20%3A%2000000000%3CBR%20%2F%3ECFBP%3A00000000%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E7%B5%82%E4%BA%86%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%3AMCU-LINK%20r0FF%20CMSIS-DAP%20V0.078(NXP%20Semiconductors)%3CBR%20%2F%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%8A%E3%83%B3%E3%83%90%E3%83%BC%3AKJKL4QM3ADBKP%3CBR%20%2F%3E%E3%83%93%E3%83%87%E3%82%AA%3APID%3A1FC9%3A0143%3CBR%20%2F%3EUSB%E3%83%91%E3%82%B9%3A%20%5C%5C%3F%5Chid%23vid_1fc9%26amp%3Bpid_0143%26amp%3Bmi_00%237%26amp%3B1db5e7dc%26amp%3B0%26amp%3B0000%23%7B4d1e55b2-f16f-11cf-88cb-001111000030%7D%3CBR%20%2F%3E%E8%89%AF%E3%81%84%E3%82%B3%E3%82%A2%E3%82%92%E6%8E%A2%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%AB%E3%82%B3%E3%82%A20%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3CBR%20%2F%3Edebug%20interface%20type%20%3D%20CoreSight%20DP%20(DAP%20DP%20ID%206BA02477)%20over%20SWD%20TAP%200%20(%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%20%E3%82%BF%E3%82%A4%E3%83%97%20%3D%20CoreSight%20DP%20ID%2C%206BA02477)%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20%E3%82%BF%E3%82%A4%E3%83%97%20%3D%20Cortex-M33%20(CPU%20ID%2000000D21)%20on%20DAP%20AP%200%3CBR%20%2F%3EH%2FW%20%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E6%95%B0%20%3D%208%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%91%E3%83%83%E3%83%81%E3%81%AE%E6%95%B0%20%3D%200%3CBR%20%2F%3EH%2FW%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E6%95%B0%20%3D%204%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96(0)%3A%E6%8E%A5%E7%B6%9A%26amp%3B%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%80%82DPID%3A6BA02477%E3%80%82CPUID%3A00000D21%E3%80%82%E6%83%85%E5%A0%B1%3A%3CNONE%3E%3CBR%20%2F%3E%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%3A%20SWD%E3%80%82RTCK%3A%20%E7%84%A1%E5%8A%B9%E3%80%82%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%20%E3%82%AD%E3%83%A3%E3%83%83%E3%83%81%3A%20%E7%84%A1%E5%8A%B9%E3%80%82%3CBR%20%2F%3ECoreSight%E3%83%87%E3%83%90%E3%83%83%E3%82%B0ROM%E3%81%AE%E5%86%85%E5%AE%B9%3A%3CBR%20%2F%3ERBASE%20E00FE000%3A%20CID%20B105100D%20PID%200000080000%20ROM(%E3%82%BF%E3%82%A4%E3%83%970x1)%3CBR%20%2F%3EROM%201%20E00FF000%3A%20CID%20B105100D%20PID%2004000BB4C9%20ROM%20(%E3%82%BF%E3%82%A4%E3%83%97%200x1)%3CBR%20%2F%3EROM%202%20E000E000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20ARMv8-M%20type%200x0%20Misc%20-%20%E6%9C%AA%E5%AE%9A%E7%BE%A9%3CBR%20%2F%3EROM%202%20E0001000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20DWTv2%20%E3%82%BF%E3%82%A4%E3%83%97%200x0%20%E3%81%9D%E3%81%AE%E4%BB%96%20-%20%E6%9C%AA%E5%AE%9A%E7%BE%A9%3CBR%20%2F%3EROM%202%20E0002000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20FPBv2%20type%200x0%20Misc%20-%20%E6%9C%AA%E5%AE%9A%E7%BE%A9%3CBR%20%2F%3EROM%202%20E0000000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20ITMv2%20%E3%82%BF%E3%82%A4%E3%83%97%200x43%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%20%E3%82%BD%E3%83%BC%E3%82%B9%20-%20%E3%83%90%E3%82%B9%3CBR%20%2F%3EROM%202%20E0041000%3A%20CID%20B105900D%20PID%2004002BBD21%20CSt%20ARM%20ETMv4.0%20type%200x13%20Trace%20Source%20-%20Core%3CBR%20%2F%3EROM%202%20E0042000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20CTIv2%20%E3%82%BF%E3%82%A4%E3%83%97%200x14%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E5%88%B6%E5%BE%A1%20-%20%E3%83%88%E3%83%AA%E3%82%AC%E9%9B%BB%E6%B0%97%20%E3%82%B7%E3%83%A7%E3%83%83%E3%82%AF%20%E7%99%82%E6%B3%95%3CBR%20%2F%3EROM%201%20E0045000%3A%20CID%20B105900D%20PID%2004004BB907%20CSt%20ETB%20%E3%82%BF%E3%82%A4%E3%83%97%200x21%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%20%E3%82%B7%E3%83%B3%E3%82%AF%20-%20ETB%3CBR%20%2F%3EROM%201%20E0045000%3A%20CID%20B105900D%20PID%2004004BB907%20CSt%20ETB%20%E3%82%BF%E3%82%A4%E3%83%97%200x21%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%20%E3%82%B7%E3%83%B3%E3%82%AF%20-%20ETB%3CBR%20%2F%3EROM%201%20E0044000%3A%20CID%20B105900D%20PID%2004002BB909%20CSt%20%E3%82%BF%E3%82%A4%E3%83%97%200x22%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%AA%E3%83%B3%E3%82%AF%20-%20%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%3CBR%20%2F%3EROM%201%20E0046000%3A%20CID%20B105900D%20PID%2004005BB906%20CSt%20%E3%82%BF%E3%82%A4%E3%83%97%200x14%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E5%88%B6%E5%BE%A1%20-%20%E3%83%88%E3%83%AA%E3%82%AC%E9%9B%BB%E6%B0%97%20%E3%82%B7%E3%83%A7%E3%83%83%E3%82%AF%20%E7%99%82%E6%B3%95%3CBR%20%2F%3ENXP%E3%81%AE%3APN7642%3CBR%20%2F%3EDAP%20%E3%82%B9%E3%83%88%E3%83%A9%E3%82%A4%E3%83%89%E3%81%AF%201024%20%E3%83%90%E3%82%A4%E3%83%88%20(256%20%E3%83%AF%E3%83%BC%E3%83%89)%3CBR%20%2F%3Ev.2%20%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AA%20PN7642.cfx%20%E3%82%92%E6%A4%9C%E6%9F%BB%3CBR%20%2F%3E%E7%94%BB%E5%83%8F%20'PN7642%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%202024%20%E5%B9%B4%204%20%E6%9C%88%205%20%E6%97%A5%2018%3A22%3A54'%3CBR%20%2F%3E(%2065%20)%20%E3%83%81%E3%83%83%E3%83%97%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E5%AE%8C%E4%BA%86%3CBR%20%2F%3E%E6%8E%A5%E7%B6%9A%E6%B8%88%E3%81%BF%3A%20was_reset%3Dfalse%E3%80%82was_stopped%3Dtrue%20%E3%81%A7%E3%81%99%3CBR%20%2F%3E%E3%83%9D%E3%83%BC%E3%83%883330%E3%81%B8%E3%81%AEtelnet%E6%8E%A5%E7%B6%9A%E3%82%92%E5%BE%85%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3EGDB%E3%83%8E%E3%83%B3%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%E6%9C%89%E5%8A%B9%3CBR%20%2F%3EFreeRTOS%20%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%83%90%E3%83%83%E3%82%AF%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCPN7642.cfx%E3%82%92%E9%96%8B%E3%81%8F%3CBR%20%2F%3EVECTRESET%20%E3%81%8C%E8%A6%81%E6%B1%82%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81ARMv8-M%20CPU%20%E3%81%A7%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20SOFTRESET%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3ESOFT%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9(180KB%20%3D%20360%20*%20512%E3%80%810x208000%E6%99%82)%3CBR%20%2F%3EFlash%20%E3%81%A7%E3%81%AE%20150608%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x00208000%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%3CBR%20%2F%3E%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%9F%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%3A%200%E3%80%81%E5%A4%89%E6%9B%B4%E3%81%AA%E3%81%97%3A%20295%E3%80%81%E5%90%88%E8%A8%88%3A%20295%3CBR%20%2F%3E%E3%82%BB%E3%82%AF%E3%82%BF%200%20%E3%81%8B%E3%82%89%20294%20%E3%82%92%E6%B6%88%E5%8E%BB%2F%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%80%81155msec%20%E3%81%A7%20150608%20%E3%83%90%E3%82%A4%E3%83%88%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCPN7642.cfx%E3%82%92%E9%96%89%E3%81%98%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E5%AE%8C%E4%BA%86%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCPN7642.cfx%E3%82%92%E9%96%8B%E3%81%8F(%E3%81%99%E3%81%A7%E3%81%AB%E5%B8%B8%E9%A7%90)%3CBR%20%2F%3EVECTRESET%20%E3%81%8C%E8%A6%81%E6%B1%82%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81ARMv8-M%20CPU%20%E3%81%A7%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20SOFTRESET%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3ESOFT%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9(180KB%20%3D%20360%20*%20512%E3%80%810x208000%E6%99%82)%3CBR%20%2F%3EFlash%E3%81%A7%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x00233000%E3%81%AB1540%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%3CBR%20%2F%3E%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%9F%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%3A%200%E3%80%81%E5%A4%89%E6%9B%B4%E3%81%AA%E3%81%97%3A%204%E3%80%81%E5%90%88%E8%A8%88%3A%204%3CBR%20%2F%3E%E6%B6%88%E5%8E%BB%2F%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%20344-347%20(26msec%20%E3%81%A7%201540%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCPN7642.cfx%E3%82%92%E9%96%89%E3%81%98%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E5%AE%8C%E4%BA%86%3CBR%20%2F%3EFlash%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AE%E6%A6%82%E8%A6%81%3A%20152146%20%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%200.18%20%E7%A7%92%20(816.37%20KB%2F%E7%A7%92)%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%3APN7642_reset.scp%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3EPN7642%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%89%8D%E3%81%AE%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%3CBR%20%2F%3EFPB%E6%95%B0%3A8%3CBR%20%2F%3EFPB%3A0%20%E3%82%B3%E3%83%B3%E3%83%97%3A0x00208131%20(0x00208130)%3CBR%20%2F%3EFPB%3A1%E3%82%B3%E3%83%B3%E3%83%97%3A0x20003003(0x20003002)%3CBR%20%2F%3EFPB%3A2%20COMP%3A0x00000000(%E6%9C%AA%E4%BD%BF%E7%94%A8)%3CBR%20%2F%3EFPB%3A3%20COMP%3A0x00000000(%E6%9C%AA%E4%BD%BF%E7%94%A8)%3CBR%20%2F%3EFPB%3A4%20COMP%3A0x00000000(%E6%9C%AA%E4%BD%BF%E7%94%A8)%3CBR%20%2F%3EFPB%3A5%20COMP%3A0x00000000%20(%E6%9C%AA%E4%BD%BF%E7%94%A8)%3CBR%20%2F%3EFPB%3A6%20COMP%3A0x00000000(%E6%9C%AA%E4%BD%BF%E7%94%A8)%3CBR%20%2F%3EFPB%3A7%20COMP%3A0x00000000%20(%E6%9C%AA%E4%BD%BF%E7%94%A8)%3CBR%20%2F%3ECMSYSRESETREQ%20%E3%81%AE%E9%80%81%E4%BF%A1%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20Wire%20Ack%20Fault%20-%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%8C%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3EDPID%3D6BA02477%3CBR%20%2F%3ECMSYSRESETREQ%20%E3%81%AE%E5%BE%8C%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3CBR%20%2F%3ER0%20%3A%2000000000%3CBR%20%2F%3ER1%20%3A%2000208130%3CBR%20%2F%3ER2%20%3A%2000208130%3CBR%20%2F%3ER3%20%3A%2000208130%3CBR%20%2F%3ER4%20%3A%2000208130%3CBR%20%2F%3ER5%20%3A%2000208130%3CBR%20%2F%3ER6%3A00208130%3CBR%20%2F%3ER7%20%3A%2000208130%3CBR%20%2F%3ER8%3A00208130%3CBR%20%2F%3ER9%20%3A%2000208130%3CBR%20%2F%3ER10%20%3A%2000208130%3CBR%20%2F%3ER11%20%3A%2000208130%3CBR%20%2F%3ER12%20%3A%2000208130%3CBR%20%2F%3ESP%20%3A%2020008000%3CBR%20%2F%3ELR%20%3A%20FEFFFFFF%3CBR%20%2F%3E%E3%83%91%E3%82%BD%E3%82%B3%E3%83%B3%20%3A%2000208130%3CBR%20%2F%3EPSR%E7%95%AA%E5%8F%B7%20%3A%2001000000%3CBR%20%2F%3EMSP%E7%95%AA%E5%8F%B7%20%3A%2020008000%3CBR%20%2F%3EPSP%E7%95%AA%E5%8F%B7%20%3A%2000000000%3CBR%20%2F%3ECFBP%3A00000000%3CBR%20%2F%3EDPID%3D6BA02477%3CBR%20%2F%3EPN76_Sys_Hal_SoftReset%E4%BB%A5%E9%99%8D(1)%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20(0x05)%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%E3%82%A8%E3%83%B3%E3%83%89%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%E7%8A%B6%E6%85%8B%20-%20%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E8%A6%81%E6%B1%82%E5%BE%8C%20-%20%E7%8A%B6%E6%85%8B%E3%81%AE%E5%86%8D%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20RC%20Nn(05)%E3%80%82DAP%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%AE%E3%83%AF%E3%82%A4%E3%83%A4%E3%83%BCACK%E9%9A%9C%E5%AE%B3%3CBR%20%2F%3E%E7%8A%B6%E6%85%8B%20-%20%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E8%A6%81%E6%B1%82%E5%BE%8C%20-%20%E7%8A%B6%E6%85%8B%E3%81%AE%E5%86%8D%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20RC%20Nn(05)%E3%80%82DAP%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%AE%E3%83%AF%E3%82%A4%E3%83%A4%E3%83%BCACK%E9%9A%9C%E5%AE%B3%3CBR%20%2F%3E%E7%8A%B6%E6%85%8B%20-%20%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E8%A6%81%E6%B1%82%E5%BE%8C%20-%20%E7%8A%B6%E6%85%8B%E3%81%AE%E5%86%8D%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20RC%20Nn(05)%E3%80%82DAP%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%AE%E3%83%AF%E3%82%A4%E3%83%A4%E3%83%BCACK%E9%9A%9C%E5%AE%B3%3CBR%20%2F%3E%E6%AC%A1%E3%81%AE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%AB%E3%82%88%E3%82%8B%E3%82%B3%E3%82%A2%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E8%AA%AD%E3%81%BF%E5%87%BA%E3%81%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20Ep(08)%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AE%E5%AE%9F%E8%A1%8C%E6%99%82%E3%81%AB%E3%82%B3%E3%82%A2%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%83%88%E3%83%AA%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%8B%E3%82%89%E3%81%AE%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20Ep(08)%E3%80%82%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AE%E5%AE%9F%E8%A1%8C%E6%99%82%E3%81%AB%E3%82%B3%E3%82%A2%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%83%88%E3%83%AA%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3EGDB%20%E3%82%B9%E3%82%BF%E3%83%96%20(C%3A%5Cnxp%5CLinkServer_1.5.30%5Cbinaries%5Ccrt_emu_cm_redlink)%20%E3%81%AE%E7%B5%82%E4%BA%86%20-%20GDB%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%AE%E5%95%8F%E9%A1%8C%3A%20%E3%83%91%E3%82%A4%E3%83%97%E3%81%8C%20GDB%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E9%96%89%E3%81%98%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E7%8A%B6%E6%85%8B%20-%20%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E8%A6%81%E6%B1%82%E5%BE%8C%20-%20%E7%8A%B6%E6%85%8B%E3%81%AE%E5%86%8D%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20RC%20Nn(05)%E3%80%82DAP%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%AE%E3%83%AF%E3%82%A4%E3%83%A4%E3%83%BCACK%E9%9A%9C%E5%AE%B3%3C%2FNONE%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E8%A1%8C%E5%8B%95%E3%81%AE%E7%90%86%E7%94%B1%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3CP%3EArtem%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1973470%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3APN7642%20C101%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AB%E5%85%A5%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1973470%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%E3%81%95%E3%82%93%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F!%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EArtem%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1971792%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3APN7642%20C101%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AB%E5%85%A5%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1971792%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Artem%3A%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%3A%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AF%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E4%B8%8D%E5%8F%AF%E8%83%BD%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E8%AD%B0%E8%AB%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FLPCXpresso-IDE-FAQs%2F02-Failed-on-connect-Ep-01-Target-marked-as-not-debuggable%2Ftd-p%2F467619%22%20target%3D%22_blank%22%3E02%3A%E6%8E%A5%E7%B6%9A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3AEp(01)%E3%80%82%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E4%B8%8D%E5%8F%AF%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20-%20NXP%20Community%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EMCU%20Link%20Pro%E3%81%AA%E3%81%A9%E3%81%AE%E4%BB%96%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%82%92%E8%A9%A6%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EDaniel%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1970296%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3APN7642%20C101%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AB%E5%85%A5%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1970296%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%E3%80%81%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E7%A7%81%E3%81%AEMCU%E3%83%AA%E3%83%B3%E3%82%AF(%E3%83%97%E3%83%AD%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84)%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%A8%E3%81%AB%E3%81%8B%E3%81%8F%E3%81%9D%E3%82%8C%E3%81%AF%E4%BE%BF%E5%88%A9%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E5%88%A5%E3%81%AE%E6%82%AA%E3%81%84%E7%97%87%E7%8A%B6%E3%81%AF%E3%80%81%E7%A7%81%E3%81%8C%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E6%96%B9%E6%B3%95%E3%81%A7%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%82%92%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22artem_pn_0-1728500285678.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22artem_pn_0-1728500285678.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F303819iFD267B0DAC305A49%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22artem_pn_0-1728500285678.png%22%20alt%3D%22artem_pn_0-1728500285678.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22artem_pn_1-1728500579387.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22artem_pn_1-1728500579387.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F303822iEE0FD2796CEEA122%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22artem_pn_1-1728500579387.png%22%20alt%3D%22artem_pn_1-1728500579387.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%80%83%E3%81%88%E3%82%89%E3%82%8C%E3%82%8B%E7%90%86%E7%94%B1%E3%81%A8%E3%81%97%E3%81%A6%E3%82%8F%E3%81%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99!%3C%2FP%3E%3CP%3EArtem%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1969533%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3APN7642%20C101%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AB%E5%85%A5%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1969533%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%3C%2FP%3E%0A%3CP%3EMCU%20Link%20pro%E3%82%92%E3%81%8A%E4%BD%BF%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3EMCU%20LINK%20pro%E3%81%AE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%80%81%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E8%A9%A6%E3%81%99%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fgetting-started-with-the-mcu-link-pro%3AGS-MCU-LINK-PRO%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EMCU-Link%20Pro%20%E5%85%A5%E9%96%80%20%7CNXP%E3%82%BB%E3%83%9F%E3%82%B3%E3%83%B3%E3%83%80%E3%82%AF%E3%82%BF%E3%83%BC%E3%82%BA%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegads%3C%2FP%3E%0A%3CP%3EDaniel%3C%2FP%3E%3C%2FLINGO-BODY%3E
