PN7462A read failure due to temperature?
1,538件の閲覧回数
NSTU
I am working on a system utilizing the PN7462AUHN to read NFC tags. I noticed that at  certain temperature band within the operational temperature range the system fails to read the NFC tag consistently. Once the chip rises above the temperature band it can read without issue. Has anyone seen this behavior with this chip before?
3 返答(返信)
1,501件の閲覧回数
nism1906
We have the same issue. And we have checked our Power, layout and antenna design. I've even provided the data to NXP and haven't heard from them yet.
1,488件の閲覧回数
danielchen
@nism1906 :
I noticed there is a similar issue in the support queue, the case subject is Communication and Thermal issues associated with PN7462AUHN. is this yours?  I will respond in that case. Thanks for feedback.
1,513件の閲覧回数
danielchen
PN7462 has been tested at full temperature range.  Not found this issue as you mentioned.  I would suggest you check your design, layout, power design , and antenna design.
