Hi Fabian,
Thanks for the instruction.
I downloaded LPCxpresso and open my SDKs successfully. I tried running the blinky example just to make sure that everything was ok and I'm block with the following error:
Error in final launch sequence
Failed to execute MI command:
-exec-run
Error message from debugger back end:
Don't know how to run. Try "help target".
(also in a screen shot attached to my message)
I can't find a solution to it do you know what may cause this ?
Thanks again,
Alexandre Pellerin
