On below MKW40Z160_cfg.h
/** Kinetis Flash memory size */
#define KINETIS_FLASH (160*1024)
If I want to use, let say, the last page with serial number, HW version, calibration data,etc... can I modify this:
#define KINETIS_FLASH (159*1024)
KW40Z_Connectivity_Software_1.0.1\ConnSw\framework\Bootloader\Bootloader_OTAP_Serial\Linker_cfg
BootloaderOTAP.icf
/******************* Map of Kinetis FLASH ***********************************
| Application |
+---------------+ - __region_BOOT_ROM_end__
| Bootloader |
+---------------+ - __region_BOOT_ROM_start__
/*- Defining Symbols -*/
define exported symbol __region_BOOT_ROM_start__ = 0x00000000;
define exported symbol __region_BOOT_ROM_end__ = (gRomSize_c / 32) - 1;
define symbol __region_RAM_start__ = 0x20000000;
define symbol __region_RAM_end__ = 0x20001fff; // limit to 8K
/*-Sizes-*/
define symbol __size_cstack__ = 0x1000;
define symbol __IntVectTable_start__ = __region_BOOT_ROM_start__;
define symbol __IntVectTable_end__ = __region_BOOT_ROM_start__ + 0x3F;
define exported symbol __BOOT_STACK_ADDRESS = __region_RAM_end__ - 7; //0x20007FF8;
define symbol __code_start__ = __IntVectTable_end__+1;
define symbol __FlashConfig_start__ = 0x00000400;
define symbol __FlashConfig_end__ = 0x0000040f;
define block CSTACK with alignment = 8, size = __size_cstack__ { };
/*** Memory Regions ***/
define memory mem with size = 4G;
define region ROM_region = mem:[from (__IntVectTable_end__ + 1) to (__FlashConfig_start__ - 1)] | [from (__FlashConfig_end__+1) to __region_BOOT_ROM_end__];
define region RAM_region = mem:[from __region_RAM_start__ to __region_RAM_end__];
define region IntVectTable_region = mem:[from __IntVectTable_start__ to __IntVectTable_end__];
define region FlashConfig_region = mem:[from __FlashConfig_start__ to __FlashConfig_end__];
/*** Initialization ***/
do not initialize { readwrite };
do not initialize { section .noinit };
initialize manually { section .data};
initialize manually { section .textrw };
initialize by copy { section .IntVectTable };
/*** Memory placements ***/
place at address mem:__code_start__ { readonly section .noinit };
place in ROM_region { readonly };
place in RAM_region { readwrite, block CSTACK};
place in IntVectTable_region {section IntVectTable};
place in FlashConfig_region { section FlashConfig };
KW40Z_Connectivity_Software_1.0.1\ConnSw\framework\Bootloader\Bootloader_OTAP_Serial\src\include\cfg
MKW40Z160_cfg.h
* Copyright (c) 2015, Freescale Semiconductor, Inc.
* All rights reserved.
* \file MKW40Z160.h
* This file contains configuration options for the above processor
* Redistribution and use in source and binary forms, with or without modification,
* are permitted provided that the following conditions are met:
* o Redistributions of source code must retain the above copyright notice, this list
* of conditions and the following disclaimer.
* o Redistributions in binary form must reproduce the above copyright notice, this
* list of conditions and the following disclaimer in the documentation and/or
* other materials provided with the distribution.
* o Neither the name of Freescale Semiconductor, Inc. nor the names of its
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
* ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/** USER SETTINGS OF KINETIS MCU */
/** Kinetis ARM Cortex-M4 model */
#ifndef _MK21D256_CFG_H
#define _MK21D256_CFG_H
#define KINETIS_MODEL KW40_48MHz
/* in the case of using USB VIRTUAL SERIAL LINK you must activate No break TRIM CHECKBOX in the master AN2295 PC Application */
/* the break impulse is replaced by using only 9 bits zero impulse */
// BREAK IMPULSE |START| |0| |0| |0| |0| |0| |0| |0| |0| |0| |0| STOP|
// ZERO IMPULSE |START| |0| |0| |0| |0| |0| |0| |0| |0| |0| |STOP|
#define BOOTLOADER_SHORT_TRIM 1
/** Bootloader flash protection */
#define BOOTLOADER_FLASH_PROTECTION 0
/** Boot timeout after POR (Power On Reset) for wait to connect Master **/
/** BOOT_WAITING_TIMEOUT * 10ms **/
#define BOOT_WAITING_TIMEOUT 100
/* Actual used UART module */
#define BOOT_UART_BASE UART1_BASE_PTR
#define BOOT_UART_SIM_SCG_REG SIM_SCGC4
#define BOOT_UART_SIM_SCG_MASK SIM_SCGC4_UART1_MASK
#define BOOT_BUS_CLOCK (32768 * 640)
/* A range of UART baudrates is (9600 - 115200) */
//#define BOOT_UART_BAUD_RATE 9600
//#define BOOT_UART_BAUD_RATE 14400
//#define BOOT_UART_BAUD_RATE 19200
//#define BOOT_UART_BAUD_RATE 38400
#define BOOT_UART_BAUD_RATE 57600
//#define BOOT_UART_BAUD_RATE 76800
//#define BOOT_UART_BAUD_RATE 115200
//#define BOOT_UART_BAUD_RATE 128000
/** GPIO & UART pins initialization */
#define BOOT_UART_GPIO_PORT_RX PORTE_BASE_PTR
#define BOOT_UART_GPIO_PORT_TX PORTE_BASE_PTR
#define BOOT_UART_GPIO_PORT_SIM_SCG_REG SIM_SCGC5
#define BOOT_UART_GPIO_PORT_SIM_SCG_MASK SIM_SCGC5_PORTE_MASK
/* setting of multiplexer for UART alternative of pin */
#define BOOT_PIN_UART_ALTERNATIVE 3
/* setting of multiplexer for GPIO alternative of pin */
#define BOOT_PIN_GPIO_ALTERNATIVE 1
#define BOOT_UART_GPIO_PIN_RX 1
#define BOOT_UART_GPIO_PIN_TX 0
/* Actual used PIN reset setting */
#define BOOT_PIN_ENABLE_SIM_SCG_REG SIM_SCGC5
#define BOOT_PIN_ENABLE_SIM_SCG_MASK SIM_SCGC5_PORTC_MASK
#define BOOT_PIN_ENABLE_PORT_BASE PORTC_BASE_PTR
#define BOOT_PIN_ENABLE_GPIO_BASE PTC_BASE_PTR
#define BOOT_PIN_ENABLE_NUM 4
/* CRC module clock gating info */
#define BOOT_CRC_SIM_SCG_REG SIM_SCGC6
#define BOOT_CRC_SIM_SCG_MASK SIM_SCGC6_CRC_MASK
/** BOOTLOADER FEATURES SETTINGS */
#define BOOTLOADER_ENABLE_READ_CMD 1
#define BOOTLOADER_INT_WATCHDOG 0
#define BOOTLOADER_ENABLE_VERIFY 1
#define BOOTLOADER_CRC_ENABLE 1
#define BOOTLOADER_AUTO_TRIMMING 1
#define BOOTLOADER_PIN_ENABLE 0
/** CALIBRATION OF BOOTLOADER TRIM SETTINGS */
#define BOOT_CALIBRATION_GPIO_BASE PTE_BASE_PTR
* Advanced detail settings for non standard settings
#define VECTOR_TABLE_SIZE (48*4)
/* Flash block count of this MCU */
#define FLASH_BLOCK_CNT 1
/* Start address of interrupt vector table */
#define INTERRUPT_VECTORS 0x0000
/* Start address of relocated interrutp vector table */
#define RELOCATED_VECTORS 0x4000
/* Flash start address */
#define USER_FLASH_START RELOCATED_VECTORS
/* Flash end address */
//#define USER_FLASH_END 0x0003FFFF
/* Flash2 start address */
//#define USER_FLASH_START_2 0x00040000
/* Flash2 end address */
//#define USER_FLASH_END_2 0x0005FFFF
/* Size of write block */
#define FLASH_WRITE_PAGE 128
/* Size of erase block */
#define FLASH_ERASE_PAGE 1024
/* Maximal length of ID_STRING */
//#define ID_STRING_MAX 5
/* Description string */
#define KINETIS_MODEL_STR "KL46"
#define FLASH_INIT_FLASH_CLOCK { SIM_SCGC6 |= SIM_SCGC6_FTF_MASK; }
#define FLASH_BASE_PTR FTFA_BASE_PTR
#define FLASH_FSTAT FTFA_FSTAT
#define FLASH_FSTAT_CCIF_MASK FTFA_FSTAT_CCIF_MASK
#define FLASH_FSTAT_ACCERR_MASK FTFA_FSTAT_ACCERR_MASK
#define FLASH_FSTAT_FPVIOL_MASK FTFA_FSTAT_FPVIOL_MASK
#define FLASH_FSTAT_RDCOLERR_MASK FTFA_FSTAT_RDCOLERR_MASK
#define FLASH_FSTAT_MGSTAT0_MASK FTFA_FSTAT_MGSTAT0_MASK
#endif//MK21D5_CFG_H
