LQI not updating in JN5168 Zigbee module
2,628 次查看
aloysiusnishant
I am using JN5168 zigbee chip. While 2 modules are connected, LQI is updating only when the modules are moved far away from each other. If the modules are moved closer from long distance, LQI is not updating. Please guide me on this issue ASAP.
8 回复数
2,365 次查看
aloysiusnishant
Hi Mario,
               My company does not allow to share the code. What does AN means?
Aloysius
2,365 次查看
mario_castaneda
Hi Aloysius,
If you want, we can discuss your issues internally, the communication will be only you and our technical support. The support will be by email.
https://community.nxp.com/docs/DOC-329745
The application note that you take as reference
Mario
2,365 次查看
aloysiusnishant
Hi Mario,
               Every time i am sending a data from end-device to coordinator. But i am reading LQI in End-Device. Is that correct?
Mario
2,365 次查看
mario_castaneda
Hi Aloysius,
Could you please share your implementation? and what is the AN that you are taking as a reference?
Mario
2,365 次查看
mario_castaneda
Hi Aloysius,
As you know the LQI  value indicates the signal strength of the last packet received from the relevant neighbouring node. You have to update some value, send some message. What is the AN that you are working on?
Mario
2,365 次查看
aloysiusnishant
hi Mario,
For better explanation, If both the devices are near, LQI is in good state. If the modules are moved away from each other , LQI is gone to poor state (i.e) LQI as 40. Then if we move the devices again to near (1 cm distance between both the modules), LQI is still in same poor state (i.e) same LQI as 40 and its not updating.
Thank you,
Aloysius
2,365 次查看
mario_castaneda
Hi Aloysius,
As you know the LQI  value indicates the signal strength of the last packet received from the relevant neighbouring node. So, if you do not move the device, or if both don't have some interference the LQI value will have a similar value.
But, remember the LQI value  measure in the range 0-255 of the signal strength of a packet received over a radio link
Mario
2,365 次查看
aloysiusnishant
Hi Mario,
Both the devices are connected. One is coordinator and another one is end-device. If i move the end-device away from coordinator and i read LQI in end-device. LQI is updating. But if i again come closer to the coordinator and read LQI in end-device, its not updating. That means, i am receiving the same LQI which i get when both the modules are away.
Aloysius
