KW0x using mbed os 3.0 with 6lowpan stack and mbed device server
le_florin
I want to build a 6LoWPAN network 868 MHz and i want to use ​KW0x. Can i do that using mbed os 3.0 with 6lowpan stack and mbed device server?
Labels (2)
Tags (3)
EarlOrlando
Senior Contributor II
Hello Florin,
Unfortunately, mbed doesn't support the KW0x MCUs so you won't be able to use its stack.
The available software for this MCU can be downloaded from the Freedom Development Board for Kinetis KW0x​ site.
Earl Orlando.
