code is as follows, I didn't write this code and I am unable to find out at which point does the reset happens. But it did happen during this code. Any insight? Thanks
 * This code runs from eSRAM (on-chip SRAM).
.global kinetis_suspend_to_ram
 .global kinetis_suspend_to_ram_end
 .align 4
kinetis_suspend_to_ram:
 push {lr}
 * Put DDR into self-refresh
 ldr r0, ddr_cr16
 mov r1, #0x10000
 add r1, #0x0
 str r1, [r0]
ldr r0, ddr_cr15
 mov r1, #0x10000
 add r1, #0xF
 str r1, [r0]
ldr r0, sim_mcr
 ldr r1, [r0]
 add r1, #0x1
 str r1, [r0]
 * Disable all DDR I/O pins
 * Disable DDR_DQS
 ldr r0, sim_mcr
 ldr r1, [r0]
 movw r2, #0xFFF3
 movt r2, #0xFFFF
 and r1,r2
 str r1, [r0]
 * Disable clock to the DDR controller
 ldr r0, sim_scgc3
 ldr r1, [r0]
 movw r2, #0x0
 movt r2, #0xBFFF
 and r1,r2
 str r1, [r0]
 * We switch the MCG mode from PEE all the way to BLPI.
 * BLPI = PLL is disabled, FLL is disabled, clock is derived
 * from the internal refernence clock.
 * We need that so that on wake up from VLPS the Kinetis
 * returns to BLPI, rather than automatically return to PBE,
 * resetting the clocks and hence baud rates for UART, etc.
 * Switch from PEE to PBE
 ldr r0, mcg_c1
 ldrb r1, [r0]
 orr r1, #0x80
 strb r1, [r0]
 * Wait until CLKS has switched to PBE
1:
 ldr r0, mcg_s
 ldrb r1, [r0]
 and r1, #0x0C
 cmp r1, #0x08
 bne 1b
 * Switch from PBE to FBE
 ldr r0, mcg_c6
 ldrb r1, [r0]
 and r1, #0xBF
 strb r1, [r0]
 * Wait until CLKS has switched to FBE
1:
 ldr r0, mcg_s
 ldrb r1, [r0]
 and r1, #0x20
 cmp r1, #0x00
 bne 1b
 * Switch from FBE to FBI
 ldr r0, mcg_c1
 ldrb r1, [r0]
 and r1, 0x3F
 //orr r1, #0x46
 orr r1, #0x40
 strb r1, [r0]
 * Wait until CLKS has switched to FBI
1:
 ldr r0, mcg_s
 ldrb r1, [r0]
 and r1, #0x0C
 cmp r1, #0x04
 bne 1b
 * Switch from FBI to BLPI. Set LP
 ldr r0, mcg_c2
 ldrb r1, [r0]
 orr r1, #0x02
 strb r1, [r0]
 * Switch to Deep Sleep
 dsb
 isb
nop
 nop
 nop
 nop
wfi
 * When at this point, we have been woken from Deep Sleep.
 * Since we entered VLPS in BLPI Mode, we exit in BLPI mode as well.
 * Switch from BLPI to FBI. Unset LP
 ldr r0, mcg_c2
 ldrb r1, [r0]
 and r1, #0xFD
 strb r1, [r0]
 * Switch from FBI to FBE
 ldr r0, mcg_c1
 ldrb r1, [r0]
 and r1, #0x3B
 orr r1, #0x82
 strb r1, [r0]
 * Wait until reference clock has switched to external clock
1:
 ldr r0, mcg_s
 ldrb r1, [r0]
 and r1, #0x10
 cmp r1, #0x10
 beq 1b
1:
 ldr r0, mcg_s
 ldrb r1, [r0]
 and r1, #0x0C
 cmp r1, #0x08
 bne 1b
 * Switch from FBE to PBE
 ldr r0, mcg_c6
 ldrb r1, [r0]
 orr r1, #0x40
 strb r1, [r0]
 * Wait until PLL1 has locked up
1:
 ldr r0, mcg_s2
 ldrb r1, [r0]
 and r1, #0x40
 cmp r1, #0x40
 bne 1b
 * Switch from PBE to PEE
 ldr r0, mcg_c1
 ldrb r1, [r0]
 and r1, #0x3F
 strb r1, [r0]
 * Wait until CLKS switches to PEE
1:
 ldr r0, mcg_s
 ldrb r1, [r0]
 and r1, #0x0C
 cmp r1, #0x0C
 bne 1b
 * Enable all DDR I/O pins
 * Enable DDR_DQS
 ldr r0, sim_mcr
 ldr r1, [r0]
 add r1, #0xC
 str r1, [r0]
 * Enable the clock to the DDR controller
 ldr r0, sim_scgc3
 ldr r1, [r0]
 orr r1, #0x4000
 str r1, [r0]
 * Take DDR out of self-refresh
 ldr r0, sim_mcr
 ldr r1, [r0]
 movw r2, #0xFFFE
 movt r2, #0xFFFF
 and r1,r2
 str r1, [r0]
ldr r0, ddr_cr15
 mov r1, #0xF
 str r1, [r0]
nop
 nop
 nop
 nop
 * Return to the kernel code running from DDR
 pop {pc}
 bx lr
.align 4
ddr_cr15 :
 .word 0x400AE03C
ddr_cr16 :
 .word 0x400AE040
sim_mcr:
 .word 0x4004806C
sim_scgc3:
 .word 0x40048030
mcg_c1:
 .word 0x40064000
mcg_c2:
 .word 0x40064001
mcg_c6:
 .word 0x40064005
mcg_s:
 .word 0x40064006
mcg_s2:
 .word 0x40064012
.align 4
kinetis_suspend_to_ram_end:
 .word 0
