Does an errata document exist for the K32W041 or K32W061 processor?
I want to know what problems exist in the hardware so I can create a more stable product.
Examples I know of and which would be reason enough to publish such a document:
- Brown out detection has a feature to reset the CPU, but will keep the CPU in reset forever until a hard reset or PAD RSTN. This makes this reset feature (almost) useless as a safety feature.
- Synchronous ADC not supported? There are strong hints synchronous mode for the ADC is not supported, see the comment for ASYNMODE in K32W061.h:
ASYNMODE - Select clock mode. 0: Synchronous mode. Not Supported.
But User Manual UM11323 rev. 1.2 (the most recent from the NXP website) states: "Two clocking modes are available, synchronous mode and asynchronous mode."
Solved! Go to Solution.
Hope you are doing well.
Here is the Errata Documentation available for the K32W061/K32W041: K32W061 Errata.
There is also more documentation on its product page: K32W061/41.
Thanks, I was feeling stupid for not finding the document, but I see it's less than 1 month old.
