K32W multilink download
2,210 次查看
danieltseng
Contributor V
Refer to UM11393  ch 2.9.2.
I can't find J1, but looking at the file J1 should refer to J2 usb interface
Using MCUXpresso IDE to burn K32W Carrier board via Multilink and SWD, the following error message will appear.
  • KW
6 回复数
2,078 次查看
danieltseng
Contributor V
Dear Mario,
Thank you for your response, currently resolved.
2,078 次查看
danieltseng
Contributor V
I have tried using the LPC-link2 chip from J15 USB to SWD is OK.
2,078 次查看
mario_castaneda
Hi Daniel,
Unfortunately, K32W is supporting the following probes:
Link2 debug probe with ARM’s CMSIS-DAP and SEGGER J-Link protocol options.
Boards user manual: https://www.nxp.com/docs/en/user-guide/UM11393%20.pdf
NXP open SDA J& link2:
   LPC-Link2 | NXP
  OpenSDA Serial and Debug Adapter | NXP
Sorry for any inconvenience that this may cause you.
Mario
2,078 次查看
mario_castaneda
Hi Daniel,
That is great. I am working on Multilink support.
I will get back to you in the other post.
Mario
2,077 次查看
danieltseng
Contributor V
Using MCUXpresso IDE to burn K32W Carrier board via Multilink and SWD ?
2,078 次查看
mario_castaneda
Hi Daniel,
I hope you are doing great.
I have been programming the JN device using the SWD interface. Did you try to debug using the LPC?
Note: We are working with the Multilink. I will get back to you with some updates on this.
Mario
