my application on the JN5179 is running stable without any issues, but when compile the final release and disable all TRACE output I get issues.
Without TRACE the application will join to network and then it stuck. What could be the issue? Timing problems?
Kind regards,
Jurij
Hi Jurij,
What is the AN that you are working on?
As you know, the JN517x has limited supported.
For more information please contact your local sales.
Mario
Hi Mario,
I have started with the JN-AN-1220-Zigbee-3-0-Sensors to build an Thermostat device.
Sure I will contact my FAE too.
Jurij
