JN5169: issue on gateway(coordinator ) to remove its endevice
3,849 次查看
erictao
Hello:
We are using JN5169(JN-SW-4168) as ZigBee-IoT-Gateway-Control-Bridge and find that it could not remove an enddevice from its neighbor table if the enddevice is offline, which cause the coordinator could not accept any new endevice as the table would get full.
Any help would be greatly appreciated to resolve this issue^_^~
The Host sends "Management Leave Request" to JN5169(ZCB)[1] to remove an endevice.
- If the enddevice is online, it would response Leave Response, so the endevice could be removed from  its neighbor table.
- If the enddevice is offline, no matter how many times the leave request is sent, the endevice info is always present in the table...
[1]JN-AN-1194-ZigBee-IoT-Gateway-Control-Bridge.pdf
3,416 次查看
limcb
ZPS_vNtSetUsedStatus ?
7 回复数
3,416 次查看
limcb
Hi, have you tried ZPS_bAplZdoTrustCenterRemoveDevice ?
3,416 次查看
erictao
Unluckily, "ZPS_bAplZdoTrustCenterRemoveDevice ()" does not help...-_-
In summary, the following functions have been tried, none of them can remove the endevice if it is offline:
- ZPS_bAplZdoTrustCenterRemoveDevice()
- ZPS_eAplZdoLeaveNetwork()
- ZPS_eAplZdpMgmtLeaveRequest()
3,417 次查看
limcb
3,416 次查看
erictao
Great, it proved to be worked!
Finally I use the following two APIs to resolve this:
ZPS_vNtSetUsedStatus()
ZPS_vNwkSaveNt()
3,416 次查看
vihang_jani
ZPS_vNwkSaveNt()
Have you applied only 2 APIs for leave the device when device is power off ?
3,416 次查看
limcb
More undocumented functions... ~.~
Glad that's over with.
3,416 次查看
erictao
Looks a really promising method, I will have a try and update the result.
Thank you Lim
