I downloaded AN1184_ZBP_Coordinator_JN5169.bin from JN-AN-1184 template by using BeyondStudio for NXP -> Device... It's OK.
But after that I get the error "Failed to read chip details" as below picture. ( the same error with using JN51xxProgrammer)
How can I fix it?
Any suggestions? Thank you very much.
Make sure of the connections
- SPIMISO pin is connected to ground during flashing
