JN5168 transmission and reception issue,how to set continuous wave??,Measure LQI in dBm??
shaileshkorat
1. I am working on communication between 2 JN5168 modules. When i send
   data from one module to another , receiver receives data successfully.
   But after few days , receiver module stops receiving any data. Firmware
   on both device is same. When i used sniffer , i can see packets from
   sender in both cases. So , transmission is not an issue. Is their any
   possibility that RF receiver stops working in JN5168?
2. how to set jn5168 in CW(continuous wave) mode?
3. How to represent LQI in dBm?
Tags (3)
mario_castaneda
Please look at the  Application Note: JN-AN-1172. The example provides a CW using the terminal, you could look at the implementation.
Look at the Transmit Power Test (CW Mode)
The CW mode Transmit Power Test puts the device into a transmit state, generating a continuous wave signal.
Mario
