[JN-AN-1220] Is it possible for Light-Sensor to join Control-Bridge without NFC?
1,621 次查看
alan5_lin
Dear all,
I am confused if it is necessary to use NFC for Light-Sensor (node) to join Control-Bridge (Coordinator).
Is it possible to let Light-Sensor (node) to directly join Control-Bridge (Coordinator) after power on?
Thanks!
1,549 次查看
mario_castaneda
Hi Alan,
Sure, after pressing the Reset button, the device is scanning for any open network.
Please look at the LED Indication of Different States in the documentation.
"C:\NXP\bstudio_nxp\workspace\JN-AN-1220-Zigbee-3-0-Sensors\Doc\JN-AN-1220-ZigBee-3-0-Sensors.pdf"
-If a sensor node does not find a suitable network to join, it goes into a soft sleep after scanning all the primary and secondary channels.
Mario
1,550 次查看
mario_castaneda
Hi Alan,
Mario
1,549 次查看
alan5_lin
Hi Mario,
Thanks for your information.
