How to use pressure and temperature Related custer
973 次查看
vishal_zadafiy1
Can i used relative Humidity/temperature/pressure Sensor related Cluster on same EP?
标签 (1)
1 回复
921 次查看
mario_castaneda
Hi Vishal,
Yes, you can use in the same EndPoint. This is part of the application so, also it will depend on the cluster that you are reading/writing information.
https://community.nxp.com/docs/DOC-335075
Mario
