How to receive Data from SED to Coordinator on JN5168 Module
jun951753jun951
Now that I've sent the message to the other device in the APDU how do I receive the message from the message queue?
Labels (2)
mario_castaneda
Please look at the next community post.
As you can see, the SED https://community.nxp.com/message/1012968
So, if you look into the ZigBee PRO Stack User Guide ZPS_eAplAfUnicastAckDataReq
Once the sent data has reached the first hop node in the route to its destination, a ZPS_EVENT_APS_DATA_CONFIRM event will be generated on the local node.
You could read out the data that you received. PDUM_u16APduInstanceReadNBO.
Hope it helps,
Mario
