How to get rid of on/off transition time
1,323 次查看
jacco_bezemer
I successfully used the JN-AN-1171 demo to make an incandescent light bulb dimmer for a Philips HUE system.
The HUE system is primarily used for Led lighting and when turning the light on or off it uses a transition time to create a soft on/off effect.
Since i use an incandescent bulb i want to get rid of this effect.
Is there a way to get this done at the receiver end?
Kind regards,
Jacco
标签 (2)
1 回复
1,233 次查看
Sebastian_Del_Rio
Hi Jacco, I hope you're doing well!
The related functions are included in the app_light_interpolation source and header files inside the Common_Light/Source folder. Could you please take a look at these files to see if you can remove them to skip the fading in/out effect?
Please let me know if you need any more information.
Sebastian
