How to enble bluetooth drivers in imx-warp7
1,972件の閲覧回数
vinodhulagabali
      I am working on imx-warp7, I have problem to load the bluetooth-wifi drivers using menuconfig tool. when I was running command hciconfig hci0 up and etc.. It is showing like command not found So please help me to config the drivers.
Thanks with regards
Vinod Hulagabali
4 返答(返信)
1,712件の閲覧回数
texierp
Its seems you not have bluez5 installed on your WaRP7.
Add the package to your target.
And after :
hciattach ttymxc2 bcm43xx 3000000 flow -t 20
hciconfig hci0 up
hciconfig hci0 name 'warp7 bluetooth'
hciconfig hci0 piscan
PJ
1,712件の閲覧回数
vinodhulagabali
    How to enable wifi drivers can you please help me.
Thanks with regards
Vinod Hulagabali
1,712件の閲覧回数
texierp
1,712件の閲覧回数
vinodhulagabali
     It is working now. The problem is i have not installed bluez5 So and thanks for your reply.
Thanks with regards
Vinod Hulagabali
