My gateway has burned the firmware ZigbeeNodeControlBridge, but I have found some bugs that require updating the firmware program. How to upgrade through OTA or other methods。
I apologize for the confusion. Please consider that JN5189/88T is preferred for any new Zigbee, Thread design.
You may need to develop your own implementation of this functionality. Please, refer to the ZigBee 3.0 Devices User Guide, ZigBee Cluster Library User Guide and JN-AN-1216 ZigBee 3 IoT Control Bridge User Guide (inside JN-AN-1216 folder > Doc).
Also, you may find useful the following article: ZigBee 3.0: Adding Clusters.
Eduardo.
Hello @Janson
Just to confirm, are you referring to upgrade the image of your Control Bridge when acting as a Coordinator?
Support for the OTA Upgrade cluster as a client should be implemented for Router and End Device devices. Please, take a look at JN-UG-3131 ZigBe3 Devices, Section 3.20 Control Bridge; JN-UG-3132 ZigBee3 Cluster Library Chapter 49 OTA Upgrade Cluster; and JN-AN1247 ZigBee 3 Control Bridge User Guide (from JN-AN-1247 folder > Doc), Section 5.2.8 Running OTA Upgrade.
Eduardo.
