How to Enable Uart 1 in JN5168?
1,406件の閲覧回数
dheerajsawant
Contributor V
Hello Community,
I want to use 2 uart (UART0 & UART1).
i am using AN-1229 Application Note, in this i can able to use UART0.
But now i am trying to use UART1.
How will i enable Both UARTs.
Please explain if you know about this.
(*Note)- i am aware of HardWare part.i am using DIO9 as RXD1 and DIO11 as TXD1.
Please reply as soon as possible.
Dheeraj Sawant
1,245件の閲覧回数
dheerajsawant
Contributor V
Hello All,
Now its working! :smileyhappy:
i just used 3 steps and its done
1)must enable uart 1
2) set location of uart 1 pins in programming window
3) set baud rate.
and it will works!
Thanks You
