How does USB TAP support the debugging of this IC of MWCT1013?
张云翔张
xiangjun_rong
Dear 张云翔,
Firstly, the CodeWarrior for mcu ver11.0 supports the MWIC1013, pls download the CodeWarrior for mcu ver11.0.
CodeWarrior for Microcontrollers-Eclipse IDE|NXP
I am sure that he USBTAP device supports MWIC1013 on both CodeWarrior for mcu ver11 and ver10.x, do you use CodeWarrior for mcu ver10.x? if you use it and the CW tools does not list the MWIC1013 as default processor which it supports, you can select MC56F84789. The MC56F84789 is the same chip as
Hope it can help you
Xiangjun Rong
