Gas Leak sensor not sending IAS Zone notifications
2,182 次查看
hariprasad_anum
Hi ,
   We are working with NXP (JN5189) as co-ordinator and pairing multiple zigbee sensors.
Test Setup
  1. Gas leak sensor is provisioned with smart cable.
  2. Sensor keeps sending gas leak events.
  3. After couple of hours  gas leak sensor events are not received by the co-ordinator.
Attached log with MAC Address (0XA789) details. Sensor is sending  ROUTE request instead of IAS ZONE change notification. Why is sensor not able to find route ?
In which cases will this scenario occur?
标签 (1)
1 回复
2,123 次查看
estephania_mart
Sorry for the inconvenience this might cause you, but as this product has not been released yet, the support should be done through the resources that helped you getting the device. and the information of it.
Estephania
