Example delay function using the JN-AN-1220 with JN-SW-4170 SDK
1,739 次查看
jeanbony
Hi Guys,
I want to implement a simple delay function that takes a x_ms (time in milli-second) as input argument using related functions of the JN-SW-4170 SDK.
Ex:
void delay_ms (uint32_t d_ms)
    /*JN-SW-4170 timer functions call to implemnt a delay of d_ms ?*/
Can you provide an example based on existing functions of the JN-SW4170 to implement such delay?
1,586 次查看
stephanie_m
Hello Jean Bony,
Could you please verify in your code, by using the bAHI_GetClkSource function, which is the clock used for your example?
For more information about this function, please check the Integrated Peripherals API User Guide (page 168).
Estephania
