Error Zigbee Code when connect and ONOFF 200 device on JN5169
NgocHoangNguyen
Hi guy,
I have a problem about JN5169 that when I connect and  control consecutive device (about 200 device that this error occur). After connect and control I have erase PDM 20 device / time .So how to fix this problem or solution for this problem ? Thanks
Ricardo_Zamora
Hope you are doing well. Could you please confirm the parameters used when calling the Permit Join are correct?
Is this behavior also present in a smaller network?
Ricardo
NgocHoangNguyen
I set Permit Join with Address FFFC and Interval is FC as below picture.
