Does the JN5189 sdk have a AT command APIs library?
已解决
跳至解决方案
1,559 次查看
jacinto1m
I am wondering whether the JN5189 sdk provide any AT-commands API? - I coudn't find any...
标签 (2)
标记 (3)
1 解答
1,488 次查看
estephania_mart
Sorry for the inconveniences this might cause you but there is no support for AT commands in the JN5189.
Still, I would recommend you to check the Control bridge Application note JN-AN-1247, in this application note you can send commands to the device to perform some of the ZigBee functionalities, but please check the application note to verify if this can help you in your development.
You can download this application note form the documentation section in this link JN5189 Wireless MCU for Zigbee® and Thread | NXP
Hope this helps.
Estephania
在原帖中查看解决方案
1 回复
1,489 次查看
estephania_mart
Hope this helps.
Estephania
