kw41z zigbee home automation profile 1.2??
Search instead for
gustcool2
I bought zha 1.2 sensor and want to connect sensor and kw41z board
Is it possible?
And can I use nxp zigbee home automation sdk?
I wonder if kw41z supports zigbee home automation profile 1.2.
thanks
nxf63973
Hi JunTae Lee
The FRDM-KW41Z supports the standard IEEE 802.15.4, which is the base for the ZigBee Mesh Networking protocol.
It implements the ZigBee 3.0 device profile, including the configurations and support for the previous Home Automation profile. The Zigbee stack provided in the SDK implements the Zigbee 3.0 profile, so it should be compatible with your Home Automation device profile Sensor.
Please let me know if you need more information.
