end device without association send data
Search instead for
Hi All:
how can end device without association send data to coordinator?
thanks!
Labels (2)
Hi Liang,
Could you please provide more details?
Do you have the sniffer log? What is the command that you are seeing before the association?
Mario
Hi Mario:
Thanks for your replay!
I use the 802.15.4 Stack  with JN5168,first endDevice active scan the coordinator's channel, then I want send data to coordinator without association process!
I have another device with JN5148, it can send data without association to my coordinator device, so I want to know how to do this?
liang
Hi Liang,
What is the example that you are working on?
The JN5148 is sending the data through the beacon commands, right?
Mario
Hi Mario:
I use the JN-AN-1143 TOF demo. I don't know JN5148 send data with what commands, so I want to know how JN5148 send the data!
thanks
Hi Liang Guo,
Unfortunately, the JN5148  is no longer manufacture and is not recommended for new design. It is not supported.
If you are working on JN5168 the ToF is not supported as well.
Mario
Hi Mario:
How can I use JN5168 send data through the beacon commands.
