From MKW24D RM, for the Sequence TR mode, I wonder if the Ack-only receive operation is needed and if receive option can not get a correct ACK frame, dose the MKW24D keep the receiving operation ? Is there a timeout for this receiving ? And how the software know the status if ACK frame is not been received ?
Thanks!
Solved! Go to Solution.
Hello Haidong,
The device will remain in RX mode until receiving the proper acknowledge or whenever the software aborts the sequence. Actually, software can determine the precise state of the sequence manager state machine, so it can opt to abort the TR sequence at any time and return to its IDLE state in an orderly fashion.
AngelC
Hello Haidong,
AngelC
