Zigbee plugins installed failed?
topalanlin
Hi all,
PC System:Windows 10 Home
beyondStudio version:JN-SW-4141 BeyondStudio for NXP v1308.exe
Zigbee SDK version:JN-SW-4168 ZigBee-HA-LL v2162.exe
topalanlin
Re-try several times, still failed during installation.
However, I tried to clone the whole folder (ex: C:/NXP/) from another PC which has installed well before.
Finally, it works with the cloned folder on my PC.
Ricardo_Zamora
Could you please confirm that you followed the steps mentioned on section 1.2.3(Installing the ZigBee Plug-ins) of the "BeyondStudio for NXP Installation and User Guide"?
Ricardo
topalanlin
Hi Ricardo,
Thanks for your reminder.
I will check and try later.
BR,
topalanlin
topalanlin
why3303
Could you please send me these files? I've encountered the same problem and haven't found a solution.
topalanlin
How to fix the issue about "requires 'bundle org.eclipse.emf.edit 0.0.0' "?
Please.
