ZigBee Test Client on OM15020/JN5169
Search instead for
cmrlourenco
Can the OM15020 USB dongle be used as a ZigBee Test Client?
I've downloaded BeeKit, but it doesn't seem to be compatible with the dongle's MCU (JN5169).
Is there a ZTC-enabled firmware available for the dongle in question?
I'm specifically interested in communicating with the device using serial over USB in order to send and receive ZigBee commands.
Thanks in advance.
mario_castaneda
As you know the Beekti is for the KW24 products.
But you can take a look to the Control Brigde with the ZGUI. Please take a look to the JN-AN-1216, and look up to the JN-AN-1216-ZigBee-3-0-IoT-ControlBridge-UserGuide.
C:\NXP\bstudio_nxp\workspace\JN-AN-1216-Zigbee-3-0-IoT-ControlBridge\Doc
And the GUI
C:\NXP\bstudio_nxp\workspace\JN-AN-1216-Zigbee-3-0-IoT-ControlBridge\Tools\TestGUI
Hope it helps.
Mario
