ZigBee Page Requests OTA
lvdp
Since OTA uses the normal upgrade method, the 180KByte upgrade package will take 1 hour to be sent out. I tried to use the page request method for ZigBee OTA, but encountered some problems.
The chip is JN5189
SDK version is 2.6.1
The coordinator item is JN-AN-1247
The terminal equipment project is JN-AN-1243
According to "JN-UG-3103_ZigBee Comprehensive Library User Guide" 29.7.3, I added the macro definition OTA_PAGE_REQUEST_SUPPORT in zcl_options.h.
But the result is that the server did not receive the image page request, and the ota server would reply to the image block response only after the client sent the image block request.
How to make the page request OTA?
mario_castaneda
Hi @lvdp,
Sorry for the late response.
Please look at the JN-UG-3132, please look at the Implementation in the Server Application section.
"\JN5189DK6\docs\wireless\Zigbee\JN-UG-3132-ZigBee3-Cluster-Library.pdf"
Mario
mario_castaneda
I hope you are doing great.
Following the JN-AN-1247 Control Bridge documentation, please look at the JN-AN-1244 to enabled the OTA process.
What is the process that you are following?
Do you have the sniffer log?
Mario
lvdp
    Mario:
I hope to use Page Request to get faster OTA speed.
I defined OTA_PAGE_REQUEST_SUPPORT according to 《JN-UG-3103》,But it did not enable the page request upgrade,This upgrade process, you can see the OTA_log.rar.Can you tell me how to enable page request OTA?
