Where can I find examples that implements comands for write, read and report different cluster attributes using FRDM-KW41Z boards?
Solved! Go to Solution.
Hi Alejandro, I hope you're doing well!
The ZigBee control bridge example provided in the KW41Z's SDK contains a source file showing some commands that can be sent from the coordinator to other devices to get the responses you want.
The SDK example can be found in the following path:
<…\SDK_SDK_2.2.1_FRDM-KW41Z\boards\frdmkw41z\wireless_examples\zigbee_3_0\control_bridge>
The source file with the different available commands is named "app_Znc_cmds.c" and can be found in the Source folder after importing your project.
Please let me know if you need more information.
Sebastian
Sebastian
