Will IW612 support Wi-Fi 6E?
On your web page it is Wi-Fi6 and in the application block diagram it says 5 GHz band.
I could not find detailed frequency information on this web page.
The difference between Wi-Fi6 and Wi-Fi6E is the frequency extension, so I would like to know if the 5 GHz band in your block diagram includes up to 6 GHz.
The information on the web news site does not seem to support 6 GHz, but I would like to have the correct information.
https://www.everythingrf.com/products/rf-modules/nxp-semiconductors/528-241-iw612
Yukio Oyama
Solved! Go to Solution.
I apologize for the inconveniences this might cause you, the device is WiFi 6, it supports 2.4/5 GHz, up to 80 MHz channel.
Thanks for the answer.
I understand that IW does not support Wi-Fi 6E.
Thanks for the quick answer.
Yukio Oyama
