USB dongle QN908x does not work with QTool
smittal2
I'm trying to get USB dongle QN908x to work with QTool. I referred to the document, https://community.nxp.com/docs/DOC-340384 , to set it up. However, I'm unable to make the dongle enter bootloader mode after I short TP5 to GND, and press reset button on it.
I can see a Virtual COM port when i plug in USB dongle. But QTool is unable to read it.
Can someone please help
Sandeep
arpad_toth
It fails for me too, i
plug usb in
short TP4-TP5
press reset button
virtual COM goes away, no disk drive
release reset button
virtual COM comes back, no disk drive
TP5 doesnt seem to be pulled high, or it might be a pulse.
what to do next?
mario_castaneda
Hi Arpad,
What is the device manager showing out?
The TP5 must be connected to ground. Are you sure that you are connecting to GND?
Mario
arpad_toth
The problem was that the silk screen is missaligned with the pads.
Now it works.
mario_castaneda
Hi Sandeep,
Please be sure that you are connecting the TP5 and the TP4
Are you pressing the reset button? or Did you plug the dongle after the tp5 and tp4 connection?
Mario
