Hi WIFI champ
I have a question regarding the throughput measurement.
Is there a way to measure throughput between WIFIs by connecting the WIFI module wirelessly or wired to a PC or a smartphone without using a router and an iperf?
Thanks.
Jack
Solved! Go to Solution.
Hi, @JK_Cha
We always suggest to create new case to track new questions or new issue so that we can track the issue's root cause and solution.
Let me answer here this time, but please create new case to us if you have any other new questions/issues.
I am not sure which kind of performance you want to test, but we usually test Wi-Fi throughput with iperf, test Wi-Fi RF performance with lab tool. For lab tool, we have guidance related to different chipset.
For example, UM11434-- IW416 Labtool User Guide, for 88W9098:88W9098_88Q9098_Labtool_User_Guide (Included in the MFG package) and so on.
We also have Wi-Fi Tx Power Management guide for Linux platform,AN13009.
To test wifi upload/download speed, there are some other applications like Speedtest/WiFi Analizer.
So you may focus and zoom out the question limitations, if the question are too wide and general, it will be too difficult to focus. Please let me know your customer's Wi-Fi chipset and your detail requirement.
Christine.
Hi, @james
It is necessary to use router to make sure Wi-Fi chip/module works in a BSS with your PC. So I think router is necessary.
But iperf is one of the Applications that can measure throughput, you can also use other applications to replace.
For example, NetPerf, FlowGrind, IXCHARIOT and so on.
iperf is a very common and powerful application tool to measure Wi-Fi throughput, so we usually use iperf in common. For other applications, you may need to download and learn how to use it by yourself.
Christine.
Hi Christine,
Could you please make my name unknown? This is because Anyone able to search this thread from google. I don't want to open my name.
Thanks.^^
HI, @JK_Cha
I am sorry about that and I have edited.
Hope now it's ok for you.
Christine.
Hi Christine.
I have a more question.
Customer asked about the use case of WIFI-USB dongle module.
Is there any helpful guidance about the performance measurement for USB-WIFI module?
e.g. tool, test equipment and test scenario and so on.
James
HI, @JK_Cha
Please create a new case for this new question and provide detail information(chipset, platform, interface:PCIE.SDIO,USB) and describe your requirement(which kind of performace? RF?) in details.
Thanks for your understanding.
Christine.
Hi, @JK_Cha
Christine.
