Some questions on BeyondStudio
Search instead for
I am a freshman and have Importing problems.
From No Rule to Make Target error  , I know a way to solve the problem.
However, There is no detailed explanation in the instructions of the BeyondStudio User Guide (JN-UG-3098).
I am not sure  whether the following screenshot of the operationit is correct or wrong.
Moreover, where can I learn relevant operational knowledge?
Please give me some help, thanks.
Could you please check the following thread Beyond Studio Common Errors to verify if any of those can help you in the solution?
Estephania
Hello Estephania,
I tried to do the following:
Many errors disappear, but there are still some errors.
Notice!
zhang
Hello Estephania,
I have read it Beyond Studio Common Errors .And have did the following work.
"build project"
How can I solve these next problems?
 Is this a solution?
zhang
