hi,
I connected the MCU+UWB module to a PC via USB and opened the UWBMAC-GUI program.
In the program, I connected the MCU port and clicked the
dialog commands -> UCI core control -> 1.reset the UWBS selected.
But there is no return value from the UWB module.
There is no return value for all commands, not just the "reset the UWBS" command.
The uwb module sw is a pre-flashed sw.
What should I check in this case?
Is there any way to verify that the UWB module is a legitimate module?
