Hello Team,
My customer needs to implement SDCARD but he did not found any material to perform such SD card implementation with the QN9090 Dev kit.
please advise if there is an example code to add an SD card or can you guide us to implement an SD card?
second thing, the customer wanted to know if PWM output can be set to be a logical 1 of V-REF/BIAS/BAND GAP (for example if the PWM can be at peak 2.5v)?
please advise back, Thanks in advance
Kind regards,
Shai
Hello team,
I did not hear from you for a while, I would really appreciate your support in #SDcard implementation with #QN9090 device.
Thanks in advance
kind regards,
Hi Shai,
I hope you are doing great.
Unfortunately, we do not provide any support with the SD Card. However, you could use the SPI or I2C example for a better reference for the customer implementation.
The PWM output could be 2.5V depending on the VDDE.
VDDE — Supply voltage for IO
Mario
Mario,
Thank you.
